New version 2.6.2 was released!
GeoLink Altitude Limit improvements:
Altitude is determined and calculated from multiple sensors to be more precise during demanding maneuvers.
GeoLink Return to Home and GeoFence update:
Programming through radio is allowed only when Spirit Settings is not running and the unit is not in the configuration mode.
Both features can be programmed differently for each Bank.
IMPORTANT: Please set Return to Home and GeoFence positions for Bank 1 and Bank 2 (if used).
FIX: μSpirit unit with certain Spektrum satellites were unable to correctly program new points through a radio.
GeoLink Return to Home update:
Swashplate indicates programming progress with Collective Pitch in the opposite way.
GeoLink Auto Landing update:
Descending speed can be configured individually.
Initial landing is sped up.
GeoLink Position Hold update:
Changing position by sticks is more convenient and predictable.
GeoLink Altitude Limit and Altitude Hold update:
Lift off altitude (zero) is taken at the time motor is not running.
GeoLink Altitude Hold update:
Maintaining altitude is more consistent.
GeoLink communication:
GeoLink communication stability was improved with a small Spirit units (Red and Black Edition).
Support for 16 channel Failsafe:
Failsafe can be configured for all 16 channels now.
Spektrum integration update:
FIX: Spektrum integration and telemetry were occasionally inactive when using Spektrum DX9 and multiple Spektrum satellites.
Spirit Settings software:
New Auto Save feature for saving changes to the unit instantly.
New Preset for LaHeli LA380 in the Setup Wizard.
