Hallo Zusammen,
für die Brain Software ist ja seit dieser Woche ein Update verfügbar...
Weiß zufällig jemand was sich geändert hat und ob die Firmware der Brains selbst auch "aufgefrischt" werden muss? Oder kann hier alles bleiben wie es ist?
Danke schon mal im Voraus und an alle ein schönes Wochenende!
Gruß Olaf
3.1.001 (firmware 3.1.001) 07 June 2017
- Only on Brain1 and only using S.Bus sometime some radio frames are lost causing very short breaks in the controls: Fixed
- Added KST servos in the list of page 1 of the wizard and in Servo Charts of page 2
- Added in Tail blades list, Cyclone brand
- Added Goblin 650 in model selection
- Added in ESC list, Graupner Brand
- Revised the Blade size icon "515-640"Â to "515-650"
- Auto Level checkbox activation on channel assigned to Aux now set the Auto level Gain value
- Improved some HoTT schematics
- Updated version of "README_for_HOTT_telemetry_and_integration_for _BRA IN.pdf" in the MANUALS page
- Updated version of "README_for_Jeti_integration_for_BRAIN.pdf" (use of menu key for incremental value, added graphic page for vibrations)
- Improvements to the French instructions
Das hat sich geändert.
Ob es für dich wichtig ist musst du selbst entscheiden.
- 3.1.001 (firmware 3.1.001) 07 June 2017
3.1.000 (firmware 3.1.000) 05 June 2017
â?¢ Added management of the new "HoTT + telemetry" protocol and the relative connection schemas
â?¢ Added Graupner "Telemetry"
â?¢ Added Graupner "Integration"
â?¢ Ex Bus telemetry: further revised many parameters names that now are more obvious on TX (to update names, is needed a new "SENSORS AUTO DISCOVER")
â?¢ Ex Bus telemetry: It is not possible reduce the servos frequency below 92Hz: Fixed
â?¢ Ex Bus integration: released new version of "brain.bin" file and PDF readme instructions (downloadable from MSHELI website)
- New faster autorotation bailout ramp from the governor engage (50%) point to the target RPM (pay attention if you have high "Bailout Ramp" value!)
- Governor: improved the overspeed control with nitro's
- New Boot Loader 1.7 Now is possible put the unit in Boot Loader mode shorting the TX & RX of SYS also with longer cables and also shorting CH4 & CH5 at power up (mainly for Brain2 units with Bluetooth and without the SYS connector)
- Saved in the Brain memory some new model information's (Model type, Main Blades type, Tail Blades types, Cyclic Servos type, Tail Servo type, Motor type, ESC type, Battery type, etc.) to simplify/automate/speed up the setup of the unit
- Choosing from the first page of Wizard, one of the listed Tail Servos and/or one of the listed Cyclic Servos, if the unit is in factory reset, the values in the Wizard panel 2 "Servo Setup" are set to the specified values
- Choosing from the first page of Wizard, one of the listed Models, if the unit is in factory reset, the values of the Wizard "Swashplate Type selection" and "Blades Size Selection" are set to the specified values for that model.
- Separated Servos chart for cyclic and for tail in the panel 2 "Servo Setup" of the wizard
- Now doing a double click on the row of the servo in the Servos chart, the servo chart displayed values are automatically set in to the Brain
- Added in the Servos Charts Align DS530 & DS535 standard version and "M" version and MKS DS1220, DS1230, DS1240
â?¢ Now Factory Defaulted unit record/log by default ten flight parameters at the maximum sampling rate
â?¢ In the Log reversed the polarity of the "Swash Aileron" signal so, now correspond to the polarity of the "Transmitter setup" panel
â?¢ Added a check to avoid using the same radio channel for different Calibration Channels (Dials)
â?¢ Revised variables names: RxRoll->RxAileron & SwashRoll->SwashAileron
- If radio channel assigned to "Tail gain", is disactivated with the checkbox "Is set in software", the same channel also if it is present but "greyed out" can be used for other functions
- In Advanced->Setup the active Setup is now highlighted
- Added the new "README_for_HOTT_telemetry_and_integration_for _BRA IN.pdf" in the MANUALS page
- Updated version of "README_for_ESC_datas_log_and_telemetry.pdf" (ESC telemetry work also with Futaba T-FHSS used by T10J & T6K-V2)
- Also Tail servos signal is now turned off before a firmware update to avoid displacement at the start of the firmware update that sometime happen (for update from this firmware on)
- Improved/increased/completed the Blades Size range displayed inside the icons of panel 10 "Blade Size Selection" of the wizard
- In Basic->Servo Setup: added the new kind of dotted border around the icons if the relative default values are changed from the user
- In Basic->Blades Size Selection: added the new kind of dotted border around the icons if the relative default values are changed from the user
- In Basic->Flight Style Setup: added the new kind of dotted border around the icons if the relative default values are changed from the user
- Advanced->Common->Governor, added calculators for main gear and for tail gear calculation (as in Wizard)
- Wizard panel 12 Governor, added sliders for the change of Speed1, Speed2 & Speed3 (as in Advanced)
- Improvements to French and Russian instructions
- Revised and updated English instructions
- Revised and updated Italian instructions
- Improvements/optimization/compression/reduction/speed up of the code
wie oben beschrieben:
Wenn du ein Brain2 BT hast ohne SYS I/O Port, kannst du zum kurzschließen auch die Pins CH4 & CH5 verwenden.
Ansonsten Tx und Rx vom SYS I/O.
erster Heli ESC proggen mit 100 - 100 Gasweg (hobbywing 50a)
oder wie ich zuerst mal settings im brain gemacht, danach gaswert angelernt im ESC. (nun ist der gaswert aber nicht mehr 100-100 sondern irgendwelche andere Zahlen..
Ich habe mir das Brain2 gekauft und wollte nachdem ich die neuste Firmware aufgespielt habe, meine Einstellungen abspeichern. Aber genau das macht es nicht, egal in welcher Reihenfolge. Sobald ich den Flugakku abklemme sind alle Einstellungen wieder weg, und mir wird nachdem ich die Software gestartet habe mitgeteilt das das Brain auf Werkseinstellung steht.
Kann ich vielleicht noch etwas ausprobieren oder muss ich es wieder einschicken?
Das Brain speichert jede Veränderung, welche du in der Software machst, sofort ab. Dann USB Kabel abziehen und gut. Normalerweise.
Das ist meine Vorgehensweise bei ßnderungen. Funktionierte bei meinen 3 Brains bisher immer, auch mit der neuesten Firmware.
Eventuell noch mal die Firmware erneut aufspielen.
So mache ich das bei meinen anderen Brain 1 und 2 ebenfalls. Aber bei diesem funktioniert das nicht. Sämtliche Einstellungen sind weg. Auch nachdem ich heute die neuste Firmware aufgespielt habe. Außerdem habe ich in den Eventlogs noch den gelb hinterlegten Code 103 entdeckt.
Ich fürchte das muss ich wieder zurück schicken.
