Different cycle-pitch degrees with HC3SX
  • sapca1
    sapca1
    I have a problem with the HC3SX.
    I have different cycle-pitch degrees.
    On aileron - left 12" > right 10"
    On Elevator - front 11" > Back 13"
    Transmitter is perfect callibrated (diagnose screen )
    servo-arms perfect perpendicular ( trim screen )
    swash perfect level @ mid stick.
    Gr,
    sapca
    PS : you can answer in German,I understand bud can't write it
  • Joachim HC
    Joachim HC
    AW: Different cycle-pitch degrees with HC3SX
    Are the bars in the diagnose tab travelling equal ways, left and right on aileron, up and down on elevator? Or is for example left a bit more than 100% and right a bit less than 100%?
    Otherwise I do not have an explanation for this.
    Joachim
    • sapca1
      sapca1
      Hi Joachim,
      As far as I can see,it looks perfect.
      May I reduse the values in the diagnose tab to get the same angle on both side *
      Before I had a Vbar on it, and there was the cycle-pitch on both side the same !!!
      So I don't think it's mechanical
      Gr,
      sapca
      • Joachim HC
        Joachim HC
        Actually...I have to admit that I have no idea?!?!?! Never had this before and no idea where this results from. Not from the system, that's for sure.
        Irgendjemand hier der sowas schon hatte und helfen kann?
        Joachim
        • peter2tria
          peter2tria
          Hello,
          we have had a similar issue in this forum some days ago. There one servo was brocken.
          To test this it is sufficient to change the connector of the roll servos (left/right) at the HC without dismounting the servos - only !!!! for test of the servos.
          • Jörg
            Jörg
            which heli? Which rotorhead?
            At 0° Pitch is it leveled 0° at all 4 Positions?
            Jörg
            • sapca1
              sapca1
              Logo 600 SE
              Swash @ mid-stick ( zero degrees ) perfect level !!!!
              No servo's are broken !!!!
              Gr,
              sapca
