Just an experiment to see which needle is responsible for what part of the throttle position on a YS-91-SR carburetor. I am somewhat surprised by the results. Idle needle covers 0 - 15% throttle position The mid range needle is entirely responsible for fuel delivery from 15% to 40% throttle position. The interesting bit is from 40% to 100% throttle At 50% the mid range in supplying most of the fuel, but the high speed is contributing some. At 100% throttle, the high speed needle is supplying most of the fuel, but the midrange is also contributing some.
