i can read german so if somebody has some advice it´s ok to do it in german.Best regards, Arjan.
I use CoolPower 15% too and an OS 3 glow plug. I run both with an OS32 engine though. Anyway, do you use a pipe or "just" a muffler? How is the climb rate with your helicopter? Just from what you wrote, I would say you´re running too rich. Besides, if you do use a pipe the distance between the engine and the first bounce plate (not sure if these are the proper words, besides you can usually see where this plate is installed by a little bulge at the outside of the pipe) should be around 39 cm for a 61 engine. From there you may have to shorten the distance again to get back to the correct resonance distance to boost your power.
) partly combusted fuel may remain in the engine. (If you don`t believe that, drive your car in 5th gear at 30mph for some days and visit your garage
): Take a look at the speed of your rotor head, your gear ratio and your pitch-angle. Following should help: Decrease the pitch-angle a litte bit (one or two degrees shold be enough!!) and increase the rotation speed of your engine. I´m sure, that this will help. If it doesn´t feel free to ask again or write an e-mail to me.
