1) Added support for parameter adjustment via Mikado VBar-Control.
2) Optimized flight modes: soft start function in "Ext.Gov" (external governor mode) and Throttle response to better match VBar's Governor function.
3) Optimized accuracy of the ESC current draw in the Telemetry data.
4) Optimized slow start algorithm in "Heli ELFGov" (elf speed mode) and "Heli StoGov" (storage speed mode) to make a faster and more linear start.
5) Optimized "Restart Accelerate time" function so that the blades can spool up faster according to the restart time set in the ESC.
Below is the current firmware version for each ESC:
Platinum HV 200A V4.1 --- PL-04.1.00-VBar
Platinum HV 200A V4.1 OPTO--- PL-OPTO04100VBar
Platinum HV 130A V4 --- PL-04.1.00-VBar
Platinum HV 130A OPTO V4 --- PL-04100OPTOVBar
Platinum 150A V5 --- PL-04.1.00
Platinum 120A V4 --- PL-04.1.00-VBar
Platinum 80A V4 --- PL-04.1.00-VBar
Platinum 60A V4 --- PL-04.1.00-VBar
Platinum 25A V4 --- PL-04.1.00-VBar
Firmware Update 👇👇👇
Hobbywing
