Scorpion ESC Update
  • bronti
    • 16.10.2005
    • 3465
    • sven
    Scorpion ESC Update
    ***Hey! Eyes on me! All Tribunus II users need to read below! This is CRITICAL information***
    At Scorpion we collect data, (ESC, motor size and brand used, use case, etc) from all our our RMA (warranty) cases. After reviewing the data from our RMA's we noted a higher propensity of failures on customers using certain Non Scorpion Brand Motors.
    This lead to a slew of investigations and comparative testing on our part to identify the root causes. After our investigation, we found some other brand motors use poorer quality stator material, which provide longer de-mag times, and lower torque per amp ratios. The combined effect, in certain use cases, could lead to increased chance of failure when used with Tribunus ESCs.
    To explain fully would take several pages of writing, so I will say in breif, this is not a "issue of Tribunus" but literally the fact of the motors being "un driveable" past a certain current rating.
    While we would love to just advise customers to buy our proven and quality Scorpion motors only, we realize that this is not an option, as our value customers sometimes choose other brand of motors.
    So, we have been working tirelessly over the last month testing various brand of motors and re evaluating our entire Tribunus II Firmware, adding in adaptive protections which can sense these certain kinds of motors, and allow the ESC to protect itself when used with them.
    I will stress again this update is CRITICAL. We will not be posting the list of motors which we found problematic, as we can not test all. But we found even very popular and "quality" motors on the market can have this issue. So best to just update your ESC to V70 to protect yourself regardless.
    If you do not know how to update your ESC, then please watch the below video.
    Scorpion Tribunus ESC {Tutorial} - Connecting to PC or MAC + Downloading SProto + Firmware Updates - YouTube
    In addtion we have added further protections to protect against improper use cases, as well as improved the drive algoithm even further. Also we have improved our MAH counting algorithm to provide you more accurate mah counting telemtry results.
    Also we have added new programing features such as "stick programming" to switch between heli and airplane mode. More infromation will be avaialble in the new tribunus II manual coming soon
  • bronti
    • 16.10.2005
    • 3465
    • sven
    AW: Scorpion ESC Update
    hier von World of Heli
    INFO
    - WICHTIGES SCORPION TRIBUNUS II UPDATE- V70
    Alle Tribunus II-Benutzer müssen den folgenden Text lesen! Dies ist eine wichtige Sicherheitsinformation!!
    Bei Scorpion werden die die Daten (ESC, Motorgröße und -marke, Verwendungszweck usw.) von allen unseren RMA-Fällen (Garantie) analysiert.
    Nachdem wir die Daten unserer RMAs überprüft hatten, stellten wir fest, dass bei Kunden, die bestimmte Motoren anderer Marken als Scorpion verwendeten, eine höhere Fehlerhäufigkeit auftrat.
    Dies führte zu einer Reihe von Untersuchungen und Vergleichstests seitens Scorpion, um die Grundursachen zu ermitteln. Nach der Untersuchung wurde festgestell, dass einige Motoren anderer Marken minderwertiges Statormaterial verwenden, das längere De-Mag-Zeiten und ein geringeres Drehmoment pro Ampere-Verhältnis aufweist. Der kombinierte Effekt könnte in bestimmten Anwendungsfällen zu einer erhöhten Ausfallwahrscheinlichkeit bei der Verwendung mit Tribunus Reglern führen.
    Eine ausführliche Erklärung würde mehrere Seiten in Anspruch nehmen, daher möchte wir nur kurz darauf hinweisen, dass es sich hierbei nicht um ein "Tribunus-Problem" handelt, sondern um die Tatsache, dass die Motoren ab einer bestimmten Stromstärke "unstellbar" sind.
    Obwohl wir unseren Kunden gerne raten würden, nur unsere bewährten und qualitativ hochwertigen Scorpion-Motoren zu kaufen, ist uns klar, dass dies keine Option ist, da sich unsere wertvollen Kunden manchmal für Motoren anderer Marken entscheiden.
    Daher hatt Scorpion in den letzten Monaten unermüdlich daran gearbeitet, verschiedene Motorenmarken zu testen und unsere gesamte Tribunus II-Firmware neu zu bewerten, indem adaptive Schutzmechanismen eingebaut wurden, die diese bestimmten Motoren erkennen und es dem Regler ermöglichen, sich selbst zu schützen, wenn er mit ihnen verwendet wird.
    Wir möchten nochmals betonen, dass dieses Update KRITISCH ist. Wir werden hier nicht die Liste der Motoren veröffentlichen, die als problematisch gelten, da wir nicht alle testen können. Aber wir haben festgestellt, dass sogar sehr beliebte und "Qualitäts"-Motoren auf dem Markt dieses Problem haben können. Am besten aktualisieren Sie also Ihren Regler auf V70 über Sproto, um sich in jedem Fall zu schützen.
    Wenn Sie nicht wissen, wie Sie Ihren Regler aktualisieren können, sehen Sie sich bitte das folgende Video an.
    Zusätzlich haben wir weitere Schutzmaßnahmen gegen unsachgemäßen Gebrauch hinzugefügt, sowie den Antriebsalgorithmus noch weiter verbessert.
    Es wurde außerdem die Kapazitätsmessung verbessert, um Ihnen genauere Kapazitätswerte zu liefern.
    Es wurde auch eine neue Programmierungsfunktionen hinzugefügt, wie z.B. die "Stick-Programmierung", um zwischen Heli- und Flugzeugmodus zu wechseln. Weitere Informationen finden Sie im neuen Tribunus II Handbuch, das in Kürze erscheinen wird.
    • Heli87
      • 11.10.2016
      • 8542
      Wenn das kein Tribunus Problem ist, dann wundere ich mich sehr das man da nix von den roten und blauen zu hört.
      Zuletzt geändert von Heli87; 07.09.2022, 19:46.
      • uliguid
        • 23.02.2009
        • 416
        • Uli
        Man muss nicht mal genau hinsehen, um es zwischen den Zeilen lesen zu können ...
        Es springt einem förmlich an
        • thexo
          • 16.06.2018
          • 230
          • Theodor
          • Raum Mühlacker
          Ganz Toll, vielen Dank Scorpion, jetzt weiß ich endlich, warum mein 540 € teurer Tribunus II 200 A genau nach dem 1. Akku am Egodrift Tengu 4530 HT sich für immer verabschiedet hat. Zuvor lief an dem Regler den Scorpion Ultima, das hat viele Flüge funktioniert, mir wurde aber der Motor im Sommer zu heiß, daher wollte ich den Tengu testen.
          Den Regler hatte ich dann eingeschickt zu L... H...y Die haben ihn mir zurück geschickt mit der Aussage der Regler sei zu alt (es gibt aber kein neueres Modell) und den zu Scorpion zu schicken zu aufwändig und würde auch zu lange dauern.
          Jetzt weiß ich endlich, dass es mein Fehler war. Einen derart minderwertigen Motor an solch einen hochwertigen Regler anzuschließen. Jetzt läuft der Tengu an einem "Blauen"
          Einfach nur zum Ko....
          Mik.200,480+550SE+690SX;TT.550+620EFBL;G.500S,570S +Drake;Sox600,Str7;Spec700V2;Tr5.8;VBCT
          • uliguid
            • 23.02.2009
            • 416
            • Uli
            Ich selber habe keinen Regler von Scorpion, aber ich finde solch ein Vorgehen einer Firma wirklich erbärmlich. Das geht mal gar nicht.
            Falls ein Hiweis in den Anleitungen der Regler ist, dass sie nur in Kombination mit Scorpion-Motoren feherlfrei funktionieren, nehme ich meine Kritik selbstverständlich zurück!
            Oder es handelt sich um Fake-News. Das weiß man heutzutage ja nie.
            Zuletzt geändert von uliguid; 07.09.2022, 21:28.
            • Heli87
              • 11.10.2016
              • 8542
              Dann waren die Ausfälle auf dem Global 3D mit Scorpion Regler und Motor sicher Ausnahmen.
                Diese Aussage wurde auch von Händlern in den sozialen Netzwerken verbreitet. Die Wortwahl "minderwertig" finde ich in dem Zusammenhang nicht angebracht. Andere Hersteller scheinen ihre Regler wohl besser programmieren zu können, so dass sie an "minderwertigen" Motoren nicht kaputt gehen.
                Für mich steht zumindest fest, dass ich keine Scorpion Produkte mehr kaufen werde. Solche ßußerungen finde ich das Allerletzte. Hätte man auch anders formulieren können, als anderen die Schuld in die Schuhe zu schieben.
                • Bernhard Kerscher
                  • 26.04.2010
                  • 3318
                  • Bernhard
                  Ich verstehe die Aufregung gerade nicht, Regler haben immer gebrannt und werden auch weiter brennen/def. gehen und das von allen Firmen.
                  Ich betreibe seit Jahren 2x Scorpi Tribunus V1 06/120 an Xnova Motoren und die liefen bis jetzt Top... hab ich somit Glück gehabt :-)
                  Ich bin froh das die Firmen ihre Produkte weiter entwickeln.
                  Grüße Bernhard
                    Anscheinend können andere Firmen das besser und versuchen dem Kunden bei Problemen nicht zu erzählen, dass dies an der schlechten Statorqualität von Fremdprodukten liegt.
                    • Schraubehubbrauber
                      • 28.02.2021
                      • 591
                      • Gregor
                      Das hatte ich seinerzeit mal mit nem roten... da wurde mir auch gesagt, dass der Motor billig/minderweitig sei (am Telefon, auch in dieser Wortwahl)
                      Seitdem is das ding für mich mit rot durch. Prinzipell hing das ja nur an einer Person, aber diese (überhebliche) Person verbinde ich mit der Firma.
                      Wie auch immer, ich finde es auch beschämend! Das Problem ist ja nicht, dass ein Regler fortbrennt - wie mein Vorredner schon geschrieben hat wird es das immer mal wieder geben - sonder wie mit so einem Fehler umgegangen wird.
                      • heli56
                        • 05.04.2007
                        • 3443
                        • Toni
                        • Hof / Pößneck
                        Wenn ein Hersteller sich schon zu einen SW Update inkl. so einer Ankündigung verleiten lässt, scheint es kein Einzelfall gewesen zu sein. Die Aussage des Händlers finde ich aber cool, hoffe nur das häuft sich und er nimmt es aus dem Programm mangels Nachfrage. Man liest ja immer wieder über mangelhafte Reparierbarkeit, aber hier wird es nicht mal an den Hersteller geschickt. Ach China ist cool.....
                        Mfg. Toni
                        • Heli87
                          • 11.10.2016
                          • 8542
                          Wenn es denn hier nur bei Fremdprodukten wäre.
                          Klar ist immer einfacher es auf den anderen zu schieben, aber vielleicht sollte man mal vor seiner eigenen Haustür kehren.
                            Und den goldenen Besen dazu nehmen. Die mit anderer Farbe brechen wahrscheinlich gerne ab.
                            • phiphi
                              • 01.12.2009
                              • 3974
                              • Philipp
                              • Beromünster ( LU ) CH
                              Ohne Worte
                              Gottseidank gibt es alternativen in allen Preisklassen. Regler wie auch Motoren.
                              Grx Phi
                              Ich wäre lieber am fliegen...
