Dreifach Piepen und Abregeln bei Platinum V4
  • augur
    • 22.03.2009
    • 2340
    • Nils
    • FTG Borstel-Hohenraden
    Hi.
    Kleine Frage: ist dreifach Piepen Abschaltung wegen ßberstrom? Finde die Errorcodes in der Anleitung nicht.
    Vg Nils
    SoxoS rocks! :-)
  • DieterB
    • 17.01.2016
    • 792
    • Dieter
    • Kamp-Lintfort
    AW: Dreifach Piepen und Abregeln bei Platinum V4
    08Explanations for Warning Tones
    1. Input voltage is abnormal: The ESC will measure the input voltage the moment when it-s powered on. The motor will keep beeping -BB, BB, BB� (the interval between two BBs is 1 second) when the input voltage is beyond the normal range. The warning tone won-t stop until the voltage turns normal.
    2. Throttle signal loss protection is activated: The motor will beep -B-, B-, B-� (the interval between two B-s is 2 seconds) when the ESC doesn-t detect any throttle signal.
    3. Throttle stick is not at the bottom position: The motor will beep -B-B-B-B-B-� when the throttle stick is not moved to the bottom position.
    4. Throttle range is too narrow: The motor will beep -B-B-B-B-B-� when the throttle range you set is too narrow (when designing this ESC, it requires that the entire throttle range you set cannot be less than 50% of the whole throttle range available on the transmitter.) The warning tone indicates the throttle range you set is void and you need to set it again.
    • augur
      • 22.03.2009
      • 2340
      • Nils
      Moin.
      Das kenn ich, ist aber m. E. nur für den Regler Start. Ich hab das am Ende des Fluges gehabt. Dreifaches schnelles Piepen. Ist dort auch nicht aufgeführt.
      Vg
      SoxoS rocks! :-)
