Update 1.6 für Hyperion Duo 0610
  • loopsy
    loopsy
    Ein neues Firmwareupdate ist raus:
    ßnderungen:
    (1) CHARGER INTERNAL PROTECTION UPGRADE - The connection sequence of Lithium Packs with Balancer Connector (LiPo, LiFePO4) has an impact on the components inside
    the charger. The connection sequence shown below reduces surges which occur at pack connection time, greatly reducing possibility of damage to charger components:
    In v1.6 NET/DUO firmware, additional protection is provided such that even if correct connection sequence is NOT followed, chances of charger damage are much reduced. Even so,it is always recommended that you follow the connection/disconnection (AB-BA) sequence as shown above.
    NOTE: v1.6 firmware also includes a diagnostic routine to identify chargers which have suffered internal damage. If - after updating firmware to v1.6 and attempting to balance
    charge a Lithium pack - you see an error message -OUTPUT CIRCUIT ERROR� then it means that hardware components have been damaged, and you MUST return your charger for
    repair/replacement before further use. NEVER continue to use the charger if you see this message after v1.6 upgrade, nor revert to earlier firmware!
    (2) Buzzer under SYNC MODE Charging - fix bug in which Buzzer sounded when first pack finishes. Now buzzer sounds only when both are ready to disconnect together.
    (3) Display after CC/CV END - Shows -BLC� to indicate charger is holding balance and preventing discharge until user disconnects battery
    (4) When in BALANCE MODE, main pack wires need not be connected. (With or without main wires is allowed. If connecting main wires, connect them before balancer, as above)
    (5) SYNC STORE MODE bug fixed, such that both packs STORE properly and buzzer ends when both are done. (ie: when the -slowest pack finishes)
    Firmware: http://media.hyperion.hk/dn/pc/ware/...0iUP-DUO16.zip
  • TitanRaptor
    • 08.12.2007
    • 355
    • Patrick
    • Hildesheim/Hannover
    AW: Update 1.6 für Hyperion Duo 0610
    Hmm was ist da neues dabei? mein englisch ist nicht sonderlich gut!!
    Mikado Logo 500,MSH Protos 500, powered by Turnigy, Elektrofreak
    • stein
      stein-elektronik.de
      Onlineshop
      • 18.07.2005
      • 2452
      • Hans-Willi
      Hi !
      - Im Update ist eine interne Testroutine enthalten, die schlägt Alarm, wenn ein wichtiges Bauteil defekt ist.
      - ßnderungen bei der Displayanzeige
      Und: Hyperion empfiehlt beim Anstecken und Abstecken des Lipo/A123 Packs folgendes Procedere:
      Beim Anstecken: Erst das Ladekabl an den Akku anstecken und dann erst das Balancerkabel
      Beim Abstecken: Erst das Balancerkabel von Lipo abstecken und dann erst das Ladekabel
      Anscheinend gab es da mal Probleme, die neue Firmware soll helfen, diese Probleme zu umgehen, allerdings wird o.g. Vorgehensweise beim An/Abklemmen des Akkus auch zukünftig empfohlen.
      Hans-Willi
      • stein
        stein-elektronik.de
        Onlineshop
        • 18.07.2005
        • 2452
        • Hans-Willi
        Hallo !
        Für die Leute, die mit dem Englischen Probleme haben, habe ich ein Infoblatt bezüglich der Hyperion Firmware V1.6 auf den Server gelegt:
        Hans-Willi
        • scotty600
          • 23.04.2007
          • 491
          • Matthias
          • Peking / China
          Diese Sequenz hatte ich schon immer intuitiv eingehalten, das mein Robbe Balancer das verlangt hatte.
          Jetzt muss ich mir aber mal wirklich ein PC Kabel besorgen. Habe gehört, das der Pegelwandler aus dem Kabel vom Orbit Pocket Loader funktionieren soll.
          So ein Kabel habe ich noch (steht noch immer in den Kleinanzeigen), hat da jemand Erfahrung? Ein Kabel für den Robbe PPI3 habe ich auch noch.
          • klausk
            klausk
            Hi Matthias,
            hier http://www.rc-network.de/forum/showthread.php?t=98218 findest Du eine Beschreibung. Ich habe sie aber nicht selbst ausprobiert.
            Gruß Klaus
            • loopsy
              loopsy
              Also ich habe mir (bei Hans-Willi übrigens) ein Kabel (zzgl Adapter) fertig besorgt und
              mittlerweile schon zwei Firmware Updates damit aufgespielt.
              Für 20€ fange ich doch nicht an, rumzubasteln...
              • klausk
                klausk
                Ich hatte es mir damals überlegt, als die Hyperion-Kabel noch nicht verfügbar waren, habe dann aber doch lieber gewartet. Da ich nicht soooo der Elektroniker bin hatte ich Bedenken mir viellecht wegen eigener Dummheit den Lader abzuschießen.
                Gruß Klaus
