...aus Seite 15. Auf Seite 16 gibts sogar noch Bilder
Charging LiPo Batteries in Series
The 1430C balance adapter board will allow you to charge up to two 7S batteries or any combination to make a maximum of 14S at one time. Example: Two 6S batteries, Insert the balance plugs from battery 1 in the first set of plugs marked 6S. Then insert the balance plugs from battery 2 in the second set of 6S plugs. The charger will now read this as a single 12S battery. Then you need to
attach a battery series charge adapter wire to the main power wires of the battery. Always connect the
negative wire from the charger directly to battery number one. Make sure you set the charger for the
appropriate numbers of cells.
