die neue PC-Software braucht die 5.5er Firmware
Hier die PC-SW vom 21.12.:
Hyperion PC Software
ECDS Enables:
* Full Control of the Charger Via PC
* Editing/Storage/Uploading of Memory Positions to/from Charger
* Rich Data Logging features
* "Tagging" of packs for long-term analysis
* Customizable Alarms
* And more.....
und hier die FW 5.5 für die Lader:
FIRMWARE UPDATES FOR HYPERION EOS CHARGERS
- NiXX type of charges will complain if Lipo is connected to balancer cable
- 1420 type chargers now allows for 36 & 48v PB charging.
- TVC now can be set at lower voltages to use as cutoff.
- LiXX type of battery now supports up to 100Ah packs.
- LiXX type of battery shows Ah nomination above 65000mah.
- PB now supports up to 200Ah packs.
- Ramp-up of charge now has a slight delay allowing for Generators to catch up (ECO mode).
- LCD of SuperDuo was updating/flashing too fast.
- Changes to Buzzer sound (now progress, button and end is separate settings)
- Internal watchguard function added in case of charger problem it will reset by itself as counter-measure.
viel Spaß beim updaten
Timo
Da werden sich viele bisher so gequälte Stromgeneratoren freuen
