Thunder Tigers Raptor E550S lets you experience an electric aerobatic model helicopter, straight out of the box.
The Raptor E550S possesses the max. 6S Li-po power coming with a ACE RC 1150KV motor and 80A build-in 5V/3A ESC as well as large room for mounting a 5.0Ah 6S battery pack, in which the enhanced electronics make model helicopters a functional, repairable and yet precise flying achines. Moreover, the high-precise 140° eCCPM control system and the high-performance 550 mm carbon main blades also create a reliable controlling environment. With all electronics that are 95% assembled and pre-adjusted at the factory, flying pleasure with aerobatic 3D flight is quite easily achieved.
Specifications:
â?¢Length of Fuselage: 1,150mm
â?¢Width of Fuselage : 1,40mm
â?¢Height : 390mm
â?¢Fully Equip. Weight w/o battery pack : 2,650g
â?¢Main Rotor Diameter : 1,245mm
â?¢Tail Rotor Diameter : 237mm
â?¢Gear Ratio: 1:8.5:4.56
â?¢Required Battery Pack: Lipo 6S, 3.7~5.0Ah
Features:
â?¢Highly precise 140 degree ECCPM Control System
â?¢Carbon Main Blades
â?¢Easy to install tail rod guides
â?¢Lightweight tail boom support bracket
â?¢Metal tail boom clamp
â?¢2pc Carbon Main Frames
â?¢Lower Skids
â?¢Large Battery Area
â?¢ABS Canopy
Includes:
â?¢OBL44/11-30H 1150KV Brushless Motor
â?¢BLC-80 Speed Controller
â?¢TG7200 Heading Lock Gyro
â?¢3 x S1807MG High Torque MG Servos
â?¢DS0606N Digital Tail Servo
â?¢550mm Carbon Main Blades
Quelle:
Raptor E550 Sports ARF
