Nur für Dich Waldo, ein kleines Christkindel.
liebe Grüße Peter
What's happenning at Synergy R/C
Saturday, 20 December 2008
Team Synergy would like to wish everyone a Merry Christmas and a Happy New Year! We are working hard to bring you new and exciting products in 2009. Our most current project as most of you already know is the N5. We can't spill the beans as far as a release date, but we can tell you a little bit about the model. Here are some of the features:
120 degree push/pull control system w/ single axis bell crank shaft
Main Gear Ratio - 8.5:1
Tail Gear Ratio - 4.66:1
Main Rotor Diameter: 1355mm (600mm main blades)
Tail Rotor: 245mm
Programmable Rotor Head will suit pilots from beginner to competition
Collective Pitch Range +/-14.5 Degrees
Pinch style CNC fan hub for easy "no dial" installation
Heavy duty tail hub design with dual radial AND thrust bearings on each tail blade grip
10mm hollow main shaft / 8mm solid head axle
425cc (14.5 ounce) Fuel Tank
Designed with ease of maintenance and setup in mind
Modular servo and radio trays allow for very clean radio installation
Same sleek canopy as the N9, just smaller
See you in 2009!
Team Synergy
