Quelle MSH USA bei FB.
"AWESOME UPGRADE PARTS!!!Protos Max Evoluzione Sneak Peak!
NOTE: NOT A NEW MODEL
This will be available as a boom + canopy upgrade kit. Including some additional new hardware for mounting the servo on the main frame, and new canopy mount position. It will be released in the 700/770/800 sizes (picture below is the 800). Canopy is the same for all 3 variants. The boom is very very high end, all CF. And has a different shape vs the existing CF boom.
The canopy mounting system is the same. Nearly a single motion installs and removes the canopy in seconds. Evoluzione moves the rear canopy mounts further back for the extended canopy.
Extra hint: You may spot another upgrade in the pics that will be available in the near future as well."
Dafür hält er bei einem Crash auch was aus.
