the kit will include:
1- 150mm main blade 3d
2- 150mm main blade bullet fast fly
3- TBS boom stretch + Torque Shaft Stretch (195 mm long) + 20mm compare the std, main reason to compensate the CG using big battery or 3s battery.
4- Tail Boom Support Stretch 135 mm long
ETA will be around 10 August.
All our test show that the best rpm should be lower than 130x std, our test show that 4500 / 5000 are the best, in order to get better motor torque we used lower gear ratio (with eox1101 motor we use the 9T pinion and std mg).
more pics info and video will come soon
