siehe info von Charlie Wang ("der von Thunderpower"):
Check our website for more info: thunderpower-batteries.com
To go with that, a new connector will be added to each pack. The smaller ones will get a 4-pin version, and the larger packs will have a 6-pin unit. Both types will plug into the same receptacle on the balancer. There will be a retrofit program to put these connectors on existing packs, for a nominal fee.
The "g2-lites" come from the original gen1 supplier, and so far, they seem to share the gen1's ability to stay balanced. We have many packs we're using in all our testing and I haven't found one that is not still balanced. Nonetheless, the 4000, 6000 and 8000 lite packs will eventually get the connectors as well, but mainly so that a crashed pack might be repaired. After a pack is repaired the balancer can then be used from that point forward to keep the cells to within .01V of each other, which is the tolerance level of the electronics. Retrofit of existing lite packs is not necessary until repair is actually needed. The connector can be installed during the repair.
-- Gary
also habens die bei Thundepower auch eingesehen..
(obwohl: das mit den 500 Zyklen und noch in balance klingt auch sehr interessant)
und noch ein interessantes angebot von Gary, da ich in fragte ob ich PRobleme kriegen werde mit meinem 3s2p 4200mAh-TP2-Pack bei 60A Spitzenströmen in meinem Eco8...
