Es gibt den HD800!
1.999€
Leider noch keine Photos.
Bin gespannt ob nur das Heckrohr länger ist...
HD800 pre-assembled 100%
Our Price: €1,999.00 Inc VAT
HD800 Kit to be build by customer
Features:
True 800 Class. Up to 807mm blade size is recommended and possible.
This HD800 comes as a kit. The heli will be pre-assembled in our shop to test all parts. After the heli will be put back apart to be build by the customer
Tail blades up to 126mm
Full Carbon Fiber; 100%
12s to 16s
24T stock pinion, 22, 23 and 25 available
500kV for 12s recommended, 400-430kV for 14s operations
Head-speed band: 1000 - 2000 RPM (Please contact your blade-manufacturer first for headspeeds outside the given limits of the blades)
Shore 90 dampers come with the kit. POM are included as an option
Main-gear ratio: 9,23/1
7075 Alloy
High Quality canopy made by Heli-Center Berlin
Dual Primary Belt Drive (Adjustable Primary Drive Ratio's)
Belt Driven Tail (Adjustable Tail Drive Ratio's)
High Tensile Strength Turnbuckles
100% Manufactured and Engineered in Germany!
Needed to complete:
Motor
ESC
Servos
Main and Tail Blades
Battery
FBL Unit
6ch+ TX/RX
