Quelle FB
Came up with a new creation! ������ A Goblin RAW and Goblin Kraken ultra light battery tray! ������ It is plenty stiff and has the same dimension as the original one, minus the not needed tab and the big amount of reinforcement. This battery tray has 30x30 adhesive areas that are big enough to securely mount two separate batteries. I am able to obtain perfect CG with 4000 to 5500 mAh packs. Weight savings are around 20 grams depending on filament and infill.
I can pick up the UL battery tray by one end and it will not bend, even though I am using PETG. File can be found here:
BTW I am fastening my batteries with rubber / silicone like found on many FPV quadcopters! No more mess with velcro and you can mount them in any position you like. The only function it serves is so it can't slip out horizontally.
SAB Goblin RAW and KRAKEN ultra light battery tray by PascalR11 - Thingiverse
Thingiverse - Digital Designs for Physical Objects
