schluter expert rotor head !!
  • andre94120
    Junior Member
    • 23.02.2011
    • 13
    • andre
    Hello
    Excuse me , I don't speak German
    I don't understand how Schuter Expert rotor head works !
    As pitch is changed from low or high to "MID TRAVEL" , flybar in center of the hole of rotor head plates ,it results in a 3 or 4 mm play in flybar : balls not conected anymore to the blade holder arm because to let the flybar go high or low , the balls are fixed to flybar while the flybar is up or low
    I hope you understand
    Thanks for help
    Here the photo of the head :
    Andre French oldies addict
  • Jan74
    Jan74
    AW: schluter expert rotor head !!
    Hello Andre,
    I never flew this Rotorhead, but I have a little bit expierence on the Schlüter Fixed pitch version and collective version for the system 80. The rotor head in your discussion is from 1973, the very first collective head from Schlüter. It was a simple construction without any mixing device, this was the reason, the flybar had to move up or down to increase and decrease the blade angles. So, on your picture, the links W1 and W2 have to push the flybar to increase the blade angles simultanously (collective). The blade arms are connected to the flybar by a spherical bearing and they are following each change of the flybar, either for cyclic or collective inputs.
    The Problem with this head is a limited travel for cyclic in extreme positions (up or down).
    It was then 1975, Schlüter introduced a new Head with separated Collective/Cyclic control for the Helibaby.
    Perhaps this information helped you a little bit, my english isn't perfect, sorry.
    best regards
    Jan
    • andre94120
      Junior Member
      • 23.02.2011
      • 13
      • andre
      Hi Jan
      Your English is perfect
      In Fact I understand how it works , but my problem is :
      To allow flybar moving up and down , balls are fixed to the flybar at a certain distance , but in the middle of travel of the flybar , let' say , centered in the plate holes , you get 3 or 4 mm play because the balls don't touch anymore the arms of blade holders : this is because the arms are more distant each other than up or down
      I hope you understand !
      Regards
      Andre
      • Jan74
        Jan74
        Hi Andre,
        Oh, yes, of course, now I understand!! The only possible way to not have a blocking or extreme play, would be sliding balls on the flybar. Let's see, if any other can explain us the solution.
        Comme une rotule glissante monté sûr l'arbre, si tu parle français! Je crois, c'est mieux pour les autres de continuer en anglais.
        Regards
        Jan
        Zuletzt geändert von Gast; 24.01.2014, 20:39.
        • WGS
          WGS
          • 15.09.2010
          • 675
          • Wolfgang
          Hi Andre
          you are right, there is some axial play in the stabilizer bar, but that simply doesn't matter. The stabilizer bar got out of the center when the rotor was in rotation, but you had to live with that "misbalance": In fact it worked nevertheless.
          Grüsse
          Wolfgang
          • andre94120
            Junior Member
            • 23.02.2011
            • 13
            • andre
            Hi Wolfgang
            I am surprised by the answer ! I trust you but it seemed to me It would not work .
            I was looking for a mecanical solution to push the ballsn out with springs fitted on the flybar , living the balls free , sliding on the flybar : what do you think ?
            I am restoring a Gazelle and will let you know how it works
            Thanks
            André
            • WGS
              WGS
              • 15.09.2010
              • 675
              • Wolfgang
              Hello Andrè,
              believe me, it works. I have some of these "Expert" rotor heads.
              What is the sense of restoring an oldfashioned model and change its original design at the same time?
              Of course these models were far from being perfect, but they worked, and the reason why we restore them is in most cases to get a feeling for how they worked and to fly them within the limits of their design.
              By the way: You cannot compare the collective pitch range of the "Expert" rotor with that of today's models, it was very small (same is with the Graupner Bell 212 and the Kavan JetRanger). Models of the early 70s with collective pitch are not meant to fly with a constant rpm and thrust control by the collective. They were still rpm-controlled modells with a slight amount of collective pitch to increase the responses to the lift control in hovering.
              With this small up/down movement of the stabilizer bar for collective pitch it's axial play can be neglected.
              Grüsse
              Wolfgang
              • andre94120
                Junior Member
                • 23.02.2011
                • 13
                • andre
                Hi Wolfgang
                I agree with you : flying these models like in those days
                I am an oldies addict , just look here : all are in flying condition :
                andre's gallery
                here the videos
                andre94120 - YouTube
                I know what is to fly a Bell 212 , a Kavan , .....
                I will leave like original like my other helis
                My question was : will it shake ? you answered NO . Once again I believe you
                I learned so much from this forum despite I don't speak German
                THANKS again
                Andre
                • WGS
                  WGS
                  • 15.09.2010
                  • 675
                  • Wolfgang
                  Hi Andrè,
                  I didn't say, that it does not shake at all, but there are so many possible reasons for shaking or vibrations in the design of these models,
                  that the little axial play in the stabilizer bar can be neglected.
                  Remember that people in those days flew these models with a lot more (vibration-) sensitive r/c equipment without problems.
                  Grüsse
                  Wolfgang
                  • andre94120
                    Junior Member
                    • 23.02.2011
                    • 13
                    • andre
                    Here is a video of first flight : very surprising how well it behaves "without vibrations" !!
                    Best regards
                    Andre
                    Schluter Gazelle 1973 - YouTube
                    • UliF
                      • 19.10.2010
                      • 170
                      • Uli
                      Bonjour André,
                      Sympa!
                      J'ai admiré certains de vos très beaux modèles-oldie sur "youtube" et "runryder".
                      Que diriez-vous d'une visite à la rencontre d'amoureux de vieux helicoptères de cette année à Kitzingen sur 5/6 Juillet 2014?
                      Il serait agréable d'accueillir un ami des anciens modèles-hélicoptères de l'autre côté du Rhin sur le meeting.
                      amicalement, Uli
                      • andre94120
                        Junior Member
                        • 23.02.2011
                        • 13
                        • andre
                        Bonjour
                        Très touché par l'invitation , MERCI !
                        Je vais y penser , pourquoi pas ....!
                        A bientôt
                        André
