Diabolo BE push rod lengths
  • Fasster
    Junior Member
    • 13.03.2015
    • 2
    • Andrew
    Hi Guys
    I am building a Diabolo BE and have a question regarding push rod lengths .
    From the manual it states .
    (the length of the roll servo push rods is 102.5mm overall length, measured after sanding down the injection flash on the ball links. The elevator servo push rod is 101mm long .)
    When i use the black swash leveller to check lengths and degrees , my roll/aileron servo horns are not 90° , they are past 90°. The elevator is ok .
    I'm thinking they should all be 101mm ?
    Can someone please explain this to me .
    Thank you
    Andrew
  • Fasster
    Junior Member
    • 13.03.2015
    • 2
    • Andrew
    AW: Diabolo BE push rod lengths
    Zitat von Fasster Beitrag anzeigen
    Hi Guys
    Thank you
    Andrew
    problem solved , the servos were sitting too high the mounting blocks.
