Experience with Minicopter
Dieses Thema ist geschlossen.
  • firemedic295
    Junior Member
    • 21.05.2013
    • 5
    • Ed
    Dear Fellow Diabolo Owners
    As you are most likely aware, Minicopter is in the process of undergoing a replacement program for the original secondary stage gear in all Diabolo S kits. This has become necessary due to gear failures on at least two helis. One of these failures was on my specially built Diabolo with S mechanics. After owning the S for a month or so I had decided to purchase a Diabolo as a practice heli, as my intention for the S is to use it for competing in the IRCHA Speed Cup this year. I had only between 20 and 22 flights on the Diabolo when the secondary gear failed during a gradual climb-out just 30 seconds from lift off and out of a stationary hover. The gear failure resulted in damages to the heli, two servos, main and tail blades, and a 14S Thunder Power pack. Total damages are in excess of $1400 USD. Note that this heli was fitted with off-the-shelf components and not the high-performance power-train commonly used in speed setups.
    Immediately following this incident I had contacted Gerd and sent him pictures of the damaged heli along with a close-up of the shattered metal secondary gear. I had also attached JLog files detailing the performance metrics of all prior flights conducted with head speeds ranging from 1950 rpm to 2400 rpm and right up to the last flight when the incident occurred. Additional photographic evidence was provided to assure him that the recommended gear lubrication procedure specified in the manual was followed. The heli was not used for 3D flying, violent maneuvers, or any other moves other than those generally accepted for speed flying; essentially I demonstrated that it was operated well within its specified performance envelope.
    After a few back and forth emails to Gerd, he had agreed to send me replacements for the damaged parts; some of them coming directly from him in Germany and some from Peak Aircraft here in the US. He had requested that I NOT mention this incident to anyone in return for the replacement parts. Within two days I received an email from both sources with shipping confirmation.
    On July 19th I had posted a comment on HeliFreak that read -A product like this should not be released until proven safe and reliable�. As one reads this thread, it is clearly obvious that this comment was in regard to an earlier post by a fellow HeliFreaker with respect to the testing of a new Tri-bladed head on the Diabolo S. Within 24 hours of that post I received an email from Gerd overtly indicating that I will not be receiving replacement parts because I had -broke the agreement�. Gerd also proceeded to contact FedEx and instructed them to return the shipment back to him (in Germany).
    Understand that everything I-ve mentioned in this eMail is fact, and can be supported with documentation to prove it - including photos and all the relevant email trails. The behavior exhibited by Gerd in the handling of this matter clearly speaks to his integrity and business practices; beginning from a gag order in exchange for replacement parts right up to the subsequent retraction of his offer based solely on an unrelated post on a forum. As you are all aware, I have incurred a substantial monetary loss that is undeniably a result of the failure of a component a known issue. Furthermore, considering the implied performance application of this specific heli - allowing it to operate with such a known issue becomes a safety of operation risk; which we are fortunate thus far to have not resulted in any personal or property damage (at least that I am aware of).
    Thanks All.
  • Teal69
    • 07.04.2010
    • 1279
    • Dennis
    • Berlin / Tempelhof
    AW: Experience with Minicopter
    Hi, thats a very bad story with a awkward end, but i guess u have to talk with gerd again to explain the incident in reference to the posted comment. I think its a very kiddy reaction from gerd and i think u should try to calm the waves.
    Thank u for sharing your experience with us.
    |700xx|480xx|130x|X5|G700l450PRO DFC|690sx|Banshee|V700
    • frostini
      frostini
      Da bin ich ja froh nicht mehr auf diesen Laden angewiesen zu sein.
        Wenn das so stimmt: Tolle Geschäftspraktiken!
        • patrickL3
          • 23.08.2009
          • 1531
          • Patrick
          Was war los? Meine Fremdsprachenkenntnisse sind eher
          bescheiden! Bitte nicht direkt auf Gerd hacken, es wird
          sich alles klären!
          Patrick
          • davidross87
            • 29.06.2013
            • 396
            • Linz
            In meinen Augen wurde Druck auf firemedic295 ausgeübt , dass er die Fehler nicht publik macht. Wenn das so stimmt ist das sehr fragwürdig
            Edit: Habe das Wort erpressen geändert, auch wenn es schon in diese Richtung geht
            Zuletzt geändert von davidross87; 28.07.2014, 07:37.
              Der 2. Getriebestufe ist bei einem Steigflug ausgefallen. Dieses Problem scheint aber bekannt zu sein. Der Heli ist abgestürzt. Er hat Gerd angeschrieben, ihm Fotos und Logs zukommen lassen und sie sind dann nach ein wenig eMail Verkehr übereingekommen, dass Gerd ihm die benötigten Teile schickt. Jedoch unter der Vorraussetzung, dass der Ausfall der 2. Getriebestufe von ihm nicht publiziert wird / geheim gehalten wird. Der TE hat dann in nem Forum gepostet, dass so ein Heli (Dreiblatt - Kopf) erst verkauft werden sollte, wenn er getestet und als sicher befunden wird. Das hat Gerd anscheinend gelesen und dem TE dann mitgeteilt, dass er keine Ersatzteile erhalten werde bzw. die Lieferung storniert wird, da er ja die Abmachung gebrochen hat.
              Kurz grob zusammengefasst.
              Zuletzt geändert von Manni1983; 28.07.2014, 07:46.
              • davidross87
                • 29.06.2013
                • 396
                • Linz
                Und das was er bei HF gepostet hat, hat sich nicht einmal auf seinen Fall bezogen sondern auf ein anderes Postings im Forum über einen 3-Blatt Rotorkopf
                • jochene
                  • 21.01.2005
                  • 728
                  • Jochen
                  Das sind doch gängige Praktiken.
                  Nachdem "firemedic295" dieses nun auch noch bekannt gegeben hat, wird er bestimmt nie wieder etwas vom "Gerd" erhalten.
                  Eine geänderte 2. Getriebestufe wird es bestimmt bald in neuen Baukästen geben und zusätzlich als Tuningteil.
                  In ein paar Tagen/Wochen ist das Ganze auch wieder aus den Kundenköpfen verschunden.
                  Das ist doch alles normal.
                  • patrickL3
                    • 23.08.2009
                    • 1531
                    • Patrick
                    Welches Modell ist genau betroffen:
                    -Diabolo
                    -Diabolo S
                    -Triabolo 700
                    -Triabolo 800
                    Welches Zahnrad wurde verbaut?
                    -Standart
                    -Peek
                    -Metall
                    Patrick
                    Gerd wir die Sache schon aufklären und bestimmt keine
                    Helis fliegen lassen, die einen Defekt aufweisen, also bitte
                    nett sein und keine Beleidigungen. Das kann böse nach
                    Hinten los gegen.
                    • Danoo
                      • 08.10.2009
                      • 314
                      Hallo zusammen
                      Wieviele Diabolos sind im Umlauf?
                      Wieviele davon fallen täglich runter aufgrund genau dieser Ursache?
                      Die genauen Fakten sind wohl nur dem TE und Gerd bekannt. Und ich will nicht ausschliessen, dass möglicherweise ein Fehler (Material, Fertigung, usw.) zugrunde liegen. Deshalb das kulante Verhalten dem TE gegenüber.
                      In der heutigen Zeit, wo sich Nachrichten - ob gut oder schlecht - in Sekunden um den Erdball verbreiten kann ich verstehen, dass es durchaus kontraproduktiv sein könnte für das Geschäft. Dass man darum bittet die Geschichte nicht breit zu treten ist für mich nachvollziehbar. Wenn jeder, der solche Posts liest, sachlich damit umgehen kann ist es okay. Ich befürchte aber eine emotionsgeladene Schlechtmacherei des Produktes.
                      Und nein, ich habe keinen Diabolo und bin nicht Kunde von Gerd.
                      Beste Grüsse und einen guten Wochenstart
                      Daniel
                      Have fun!
                        Anscheinend der normale Diabolo mit "normalen" Komponenten. Lt. TE also nicht am Leistungslimit.
                        Es geht ja nicht nur darum, dass ein Teil im Flug ausgestiegen ist. Das kann bei jedem Hersteller passieren. Und das Minicopter da nachbessert glaube ich auch. Jedoch finde ich es schon fragwürdig, praktisch einen Konstruktionsfehler einzugestehen, dem Geschädigten aber nur Ersatz zuzusichern, wenn dieser eine "Geheimhaltungsklausel" akzeptiert. Wirft schon ein komisches Licht auf Minicopter.
                        Natürlich alles unter der Vorraussetzung geschrieben, dass die Ausführungen des TE stimmen.
                        Es wurde auch keiner beleidigend. Der TE und der Rest hier sind eigentlich ziemlich sachlich.
                        • Teal69
                          • 07.04.2010
                          • 1279
                          • Dennis
                          Hey Patrick, niemand Beleidigt hier wem. Gerd hatte die Möglichkeit die Sache aufzuklären, hat sich dann aber dafür entschieden den Kunden mit seinen Schaden im Regen stehen zu lassen, weil ihm irgend eine Aussage von ihm nicht gefallen hat. Das finde ich doch schon sehr kindlich und lächerlich und hat nichts mit guten Service zu tun!
                          • tobi -obu
                            • 02.04.2012
                            • 2277
                            • Tobi
                            Sorry @firemedic, but i think this thread is useless.
                            As you wrote it, their behaviour was not acceptable, but we don't know the statement of the other side.
                            You should clarify it with minicopter directly again to find a solution which is acceptable for both sides.
                            T-REX 600 ESP 'FBL',
                            E-Flite Blade 180 CFX, DX8
                            • BladeMaster
                              • 10.09.2011
                              • 3372
                              • Dirk
                              An uncomely event.
                              But you know what a gentlemen agreement is ?
                              By the way, the Diabolo Speed is an extreme and rare machine, it's not comparable
                              with a normal heli for every day.
                              I hope you can solve the problem with Gerd.
                              Best regards,
                              Dirk
