Pages 23 - 29 of the attached log.
I am using a full sized V Bar with Blue sensor mounted using a metal plate.
When on the bench with the main blades off but tail blades on there are no vibration reports logged at all in the software - not one.
The Spektrum Analyzer shows nothing much only a single very low peak at around 150hz.
Headspeed in ID2 is around about 1900rpm.
I have rechecked the balance of the main blades and they are 100% perfect.
Just wondering if these vibration reports in the logs are pretty normal for this set up?
Anything to worry about?
Thanks.
