tork tube pin missing ?
  • ferry
    ferry
    hello leute
    i was just flyin my mp-xl-v91 , and i was about to land .
    then , when i was just 30 cm of the ground before landing , the tail swing around really fast . i putted it on the ground quickly , luckely no damage :]
    now , i see that the little pin what is in the antriebwelle is gone .
    it is the one that is pointing into the Ritzelwellenlagerbock .
    i look at jan's site , but no pin like that , do i have to order a complete antriebwelle , or just a loose pin ?
    and do any of you had this problem ??
    regards und danke , ferry
  • Rigid
    Rigid
    AW: tork tube pin missing ?
    Are you sure there's nothing wrong with the hole where the pin sits?
    • Ã?rgi
      • 30.01.2008
      • 516
      • Ralf
      Hello Ferry,
      read this in jan' Homepage "Aktuelles":
      Achtung !
      ich empfehle bei allen MP-Modellen mit Starrantrieb einen Schrumpfschlauch über das vordere Heckrotorabtriebskupplungstück XL-0231 zu ziehen. Somit kann der 2mm Querstift der Heckrotorantriebswelle nicht seitlich aus dem Schlitz herauswandern, falls er sich lösen sollte
      regards
      Ralph
      GruÃ? Ralph
      Voodoo 600 und Diabolo 550 sowie einige Flächen
      • drei d
        drei d
        ich glaube ferry kann mit deutsch nicht so viel anfangen
        • nexus665
          nexus665
          Hi Ferry,
          Ralph posted something relevant above, no idea whether you can read german
          Under "current news" on his website, he wrote that he suggests to all MP-Pilots with torque tube to put some shrink tubing over the "vorderes Heckrotorabtriebskupplungsstück" XL-0231. This is so the pin cannot move out of its seat in case it should disengage from its seat.
          HTH!
          Regards,
          Simon.
          • ferry
            ferry
            ok , thanks a lot for helping guys !
            i can understand deutsch , so no problem with answers in german [also i have a dictionairy]
            so on jans site he advises to put shrink tube aroud the part 0231.
            so it is better for me to buy a new , complete torque tube ?
            regards ferry
            • drei d
              drei d
              ich glaube du hast keine andere wahl.
              den pin gibt es einzeln wohl nicht zu kaufen.
              kannst aber jan fragen, ob er dir nur den pin schicken kann.
              you understand?
              • Rüdi
                Rüdi
                Jan hat seine ganzen alten MP Erstazteile auf den Müll geworfen.
                Es gibt jetzt nur noch Rigid Teile.....
                Rüdiger
                • Speedy
                  • 02.05.2003
                  • 103
                  • Benjamin
                  • Bielefeld
                  @ Rüdiger, bloß nicht, dann wäre mein Vogel auch für immer zum liegen bleiben verurteilt, da ich letztens nen crash mit meinem Mp-e hatte.
                  So grausam wird Jan wohl nicht sein
