i have a tune problem.
i have a nt , with sz91 , a henseleit [mp91] krummer , and a hatori970 .
i found out that there are 2 different 970 pipes in production.
they have different distances to the first baffle [prallplatte?]
mine is 25 cm.
the weird thing is , jan h advices in the mp91 manual , to put on the header from him , and a hatori 970 . inbetween the krummer and 970 he advises 3mm gap.
i mailed jan , and asked him what length he advices on my nt , and he says ;try 43 cm
the way jan says in the manual , the length from first flange to baffle or prallplatte , is only 38 cm.
jan's krummer is only 13 cm . i have a 10 cm vario teflon tube in between , and with that i get it to be max 43 cm .
so , how can it be that on the mp91 it is best to have 38 cm , while the same motor goes on the nt , and everybody is flying that on 41 or more ?
also , i fly 10 or 15 % nitro , does that means the length has to be longer ?
and what symptoms you get if the pipe is too short ?
if you have a hatori 970 running good , please tell me your tune tips !
antwort in deutsch ist kein problem!!
danke , gruss ferry
