i have a nt with sx c spec and clockwise running mechanism.
i want a os 91 rz engine in it
i saw that graupner sells cranks for it , but that is only linksdrehend , and i need rechtsdrehend.
i also own a mp xl v 91 with a rz engine . i tried the crank from the nt in the rz and it appears to fit , bearings are the same , stroke are the same , but i dont know if it will run as it should .
does anybody know if this is possible ?
i could get the graupner crank from the link , but then i need to convert my nt into anti clockwise and that is really expensive.
you can answer in deutsch , kein problem.
regards ferry
