Lipo-Akku-Kandidat
  • Kraeuterbutter
    Kraeuterbutter
    Lipo-Akku-Kandidat
    diese INfo hat GGodrom grad gepostet:
    Speaking of new products, here's a shot of the new 10s2p-4000 pack Charlie just sent me:
    As you can see, it is VERY light. The specs are even more impressive:
    - 3.5V at at 10C continuous load
    13C continuous rating(3.45V)
    - 3.3V at 15 C continuous(cooling require)
    Burst current at over 20C.....40A plus
    I was waiting for the next incremental performance increase to the "mix" before offering 2p-4000 packs but I had no idea it would be this big of an improvement. 13C continuous and 20+C "bursts", tranlates to 52A continuous and 80A bursts. That&#39;s well north of 2500W in a pack that weighs about 28 ounces. <David, I think we&#39;ve found your 3D-MP pack... > This will also work great in everything form my Raptor conversions, to a Logo 14.
    You&#39;ll notice it has two of the new 6-pin balancer connectors. I can&#39;t think of anything else it needs&#33;
    This pack was made from the first production sample cells. The rest of the first batch of these are on their way, and Charlie tells me packs will be available the week of January 16th.
    -- Gary
    vielleicht interessant für den 3D-MP ?
    fertig verlötet..
    inklusive Anschlüsse für Balancer
    leicht und viel Power..
  • jguther
    jguther
    Lipo-Akku-Kandidat
    Die Daten sind super. 194 Gramm weniger als die 10s5p Packs. Allerdings vom mechanischen Aufbau her wieder mal nicht so toll.
    Aber wie der Engländer sagt: The proof of the pudding is in the eating.
    Es gab schon andere Packs, die theoretisch gut waren, in der Praxis aber nicht lange gehalten haben.
    Warten wir noch ein bisschen ab, bis die ersten mal ihre 50 Zyklen drauf haben, wie&#39;s dann aussieht.
    • xconsult
      • 12.05.2003
      • 852
      Lipo-Akku-Kandidat
      Woher bekommt man fertig konfektionierte TP Packs mit Anschlüssen für Balancer ?
      Michael
      mSR TBS Disco Pro Sylphide 90 NEX E6-550 Vibe 50 NEX Forza 450
      GruÃ? Michael
      • Berthold Pätzold
        Berthold Pätzold
        Lipo-Akku-Kandidat
        die kommen erst ab Januar in den Handel.....ich warte auch schon...
        die haben die Maße die ich benötige...mehr wie 31mm breit geht nicht in meine Agusta rein ( 2x 4S4P )
        Wirst Du bei Hacker bekommen....oder jeder andere Hänlder der bisher auch TP am Lager hatte.
        • xconsult
          • 12.05.2003
          • 852
          Lipo-Akku-Kandidat
          Any News ?
          Cheers
          Michael
          GruÃ? Michael
          • xconsult
            • 12.05.2003
            • 852
            Lipo-Akku-Kandidat
            Habe bereits entsprechende Infos auf der TP Homepage gefunden
            1/20/05 - The new 12-14C "Pro Lite" packs will be released in stages, in the coming weeks. The first packs available will be the 2P-4000s, starting with the single pack TP4000-10s2p, which will be available in limited quantities starting today. Available mid-next week will be 2s2p, 3s2p, 4s2p, 5s2p, 6s2p and 8s2p pack configurations. All will be equipped with balancer connectors that will be used with the new TP-205 and TP-207 auto-detect balancers that will be released next month.
            These cells provide a "generational" improvement in performance, with a conservative discharge rating of 12C-14C continuous, and 20C-22C for 10 second "bursts".
            GruÃ? Michael
            • Running Man
              • 04.11.2002
              • 5538
              • Markus
              • Rhein-Main
              Lipo-Akku-Kandidat
              Leider ist der Balancer-Stecker vorne. Da geht es im MP etwas eng zu. Der Stecker müsste auch hinten raus.
