Versuche gerade meinen neuen Ice 100 zu Progen
gruß Michael
####################################################### # Castle Link Data File # Created: Wednesday, September 29, 2010 # Do Not Edit This File By Hand ####################################################### Hex55: 85 Brake Strength: 0 Brake Delay: .6 sec (Delayed) (*) Brake Ramp: Immediate (*) Cutoff Type: Soft Cutoff Motor Start Power: 59 Direction: Forward (*) PWM Rate: 8 Khz Current Limiting: Insensitive (175A) Cutoff Voltage: Auto Li-Po (*) Motor Timing: 5 Vehicle Type: Helicopter Throttle Type: Governor Mode Throttle Response: 5 Governor Gain: 25 Initial Spool-Up Rate: 3 Head Speed Change Rate: 4 Auto Rotate Enabled: False Governor Mode Type: Fixed Vehicle Setup - Battery Type: LiPo Vehicle Setup - Number of Cells: 6 Vehicle Setup - Battery Voltage: 22.2000 Vehicle Setup - Gear Ratio: 11.333 Vehicle Setup - Motor Kv: 1220 Vehicle Setup - Motor Number of Poles: 6 Desired Head Speed 1: 588 Desired Head Speed 2: 1803 Desired Head Speed 3: 2001 Data Log Enabled: 255 Sample Frequency: 10 Sample / Sec BEC Voltage: 5 Power-On Beep: Enabled (*) Auto-Lipo Volts/Cell: 3.0 Volts/Cell (*)
