Werft mal den Launcher an! Es gibt was neues
* NEW FEATURES:
* RPM Sensor electronics component added to aircraft editor
* Servo Mixer electronics component has new "Multiply Inputs" logic
* Gear doors can be children of other gear doors
* Support for Expansion Pack 3
* FIXED BUGS:
* Animated objects with a path-based component (e.g., roller coaster) detect collisions with their moving parts
* Roller coaster-type objects are animated smoothly
* Collision files that need to be regenerated on the user's disk because of content changes included in an update are always detected and recreated
* Resting contact forces are applied when the aircraft is on an object
* Center of gravity is calculated properly for wings after they break off
* "Breakoff Together" advanced property for wings works consistently
* Switching to a night-flying airport within MultiMode after entering using a daytime airport does not display numerous graphical artifacts
* Import/Export: Imported colorschemes are immediately added to the list of available schemes
* Import/Export: Cancelling a raw panoramic image import operation leaves no pieces behind
* Import/Export: Some error messages are improved and/or include more information
* Some resources (motors, rotor blades, etc.) that were previously restricted to Add-Ons and Expansion Packs are now available in RealFlight
* VFI: Frank Noll's Elevator lesson description is correct
* Heli Orientation Trainer: Ghost location always changes after starting a new level
* Multiplayer: IPv6 addresses are filtered out of the list of possible addresses
* Propeller-based and turbine engine components can be selected as the RPM component for a governor
* Keyboard shortcuts to change wind speed, wind direction, sun inclination, and sun azimuth adhere to the Windows keyboard repeat rate and delay settings
* Misc. user interface improvements and corrections
* Launcher: A specific type of download error which made it possible for the online update to leave some files updated and some not, thereby corrupting the installation, is now properly detected. If the error occurs, the update process will abort as expected and leave the app in its uncorrupted pre-update state
* AIRCRAFT CHANGES:
* Albatros DVa (AO4): Tail rests normally on the ground without bouncing
* Bell 222 (both versions): Retracts are located on the 3-position switch instead of the knob. Gear is down in normal flight mode and up in Idle Up 1 or 2
* ElectroStreak: Tail rests normally on the ground without bouncing
* Extra 330 (AO3): Physics and visual rudder are properly aligned, and elevator is properly trimmed
* FlyZone SkyFly: Saving the color scheme to disk for editing is allowed
* Lancair ES (AO5): Decreased flap-elevator mix prevents nose from dropping when flaps are deployed
* Osprey (AO5): Overall flight behavior is improved, model is more responsive, and handling at low engine output is more realistic
* P-6E Hawk (EP2): Flying wires are colored black
* Schweizer: CG adjustment eliminates the tendency to pitch forward
* Simple Flier: Location and size of ruddervators in physics corresponds more closely to the graphical mesh. Trim is also slightly improved
* Slinger: Aircraft no longer enters unrecoverable tumble
* WildRC's Mini IFO: Properly trimmed
