Aeorofly Professional
  • Heliflying
    Heliflying
    Mei Freund hat ein Problem mit seinem Gamecomander. Sobald er das Programm startet funktioniert es nur für 5 sec. dann hängt sich der Computer auf.
    Bitte um rasche Hilfe!!!!!!!
    Aktuelle Version 1.6.8.6
    Grafikkarte FX-5700VE 128 MB neuesten Treber heruntergeladen
    Betriebssystem XP
    Danke,
    Hier noch die benötigte TM.LOG Datei
    tm: Library Version 4.0, Copyright © 1999-2003, IPACS
    tm: http://www.ipacs.de
    tmsystem: init random with 794680390
    tmsystem: cpu type=(nlogical=1) (nphysical=1) (hyper-threading disabled)
    tmsystem: cpu=2800 Mhz
    tmsystem: memory=(physical=510MB, avail=231MB) (virtual=2047MB, avail=1905MB)
    tmsystem: operating system=Microsoft Windows 2000 Version 5.0 (Build 2195)
    afdesign: init ok
    tmgl: loading font v2 texture/serif10.tmf=(256x256) (32x255) ok
    tmgl: loading mouse texture/mouse.tmt=ok
    tmprogram: AeroFly Professional Version 1.6.8.6, Copyright © 1998-2004 IPACS
    loading configfile config/main.mcf=ok
    loading player configfile config/player1.mcf=ok
    loading player configfile config/player2.mcf=fail
    directsound: register sound sound/beep.wav=ok
    directsound: register sound sound/balloon.wav=ok
    directsound: register sound sound/crash.wav=ok
    directsound: register sound sound/splash.wav=ok
    directsound: register sound sound/glider.wav=ok
    directsound: register sound sound/glider2.wav=ok
    directinput: init=ok
    tmsystem: current monitor frequency=60
    init window=(window=1024x768) (screen=1024x768) (32bpp) (60Hz) (fullscreen)
    directsound: init=(speakerconfig=unknown) (certified) (cont.rate) (primary 16bit) (samplerates 4000,192000) (64 hwbuffers) (0 hwbytes)
    init pixelformat=ok
    gl: vendor=NVIDIA Corporation, renderer=GeForce FX 5700VE/AGP/SSE2, version=2.0.0
    gl: (viewport=4096x4096) (texturesize=4096) (stencil=8)
    gl: extensions=GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_half_float_pixel GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_object GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_paletted_texture GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_shared_texture_palette GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_vertex_array GL_HP_occlusion_test GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
    wgl: extensions=WGL_ARB_buffer_region WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_render_texture WGL_EXT_extensions_string WGL_EXT_swap_control WGL_NV_float_buffer WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle
    gl: extensions=(lockarrays) (multitexture) (pointparameter) (vertexbufferobject) (paletted texture) (separate color) (anisotropic filter of 8.00)
    wgl: extensions=(wglpixelformat) (wglrendertexture) (swapcontrol)
    gl: reducing max texture size from 4096 to 2048
    tmsystem: fullscreen modes=(640x480x16x60) (rj-640x480x16x70) (rj-640x480x16x72) (rj-640x480x16x75) (rj-640x480x16x85) (rj-640x480x16x100) (rj-640x480x16x120) (rj-640x480x16x140) (rj-640x480x16x144) (rj-640x480x16x150) (rj-640x480x16x170) (rj-640x480x16x200) (rj-640x480x16x240) (rj-720x480x16x60) (rj-720x576x16x50) (rj-720x576x16x60) (800x600x16x60) (rj-800x600x16x70) (rj-800x600x16x72) (rj-800x600x16x75) (rj-800x600x16x85) (rj-800x600x16x100) (rj-800x600x16x120) (rj-800x600x16x140) (rj-800x600x16x144) (rj-800x600x16x150) (rj-800x600x16x170) (rj-800x600x16x200) (rj-800x600x16x240) (rj-848x480x16x60) (rj-848x480x16x70) (rj-848x480x16x72) (rj-848x480x16x75) (rj-848x480x16x85) (rj-848x480x16x100) (rj-848x480x16x120) (rj-848x480x16x140) (rj-848x480x16x144) (rj-848x480x16x150) (rj-848x480x16x170) (rj-848x480x16x200) (rj-848x480x16x240) (rj-960x600x16x60) (rj-960x600x16x70) (rj-960x600x16x72) (rj-960x600x16x75) (rj-960x600x16x85) (rj-960x600x16x100) (rj-960x600x16x120) (rj-960x600x16x140) (rj-960x600x16x144) (rj-960x600x16x150) (rj-960x600x16x170) (rj-960x600x16x200) (rj-960x600x16x240) (1024x768x16x60) (rj-1024x768x16x70) (rj-1024x768x16x72) (rj-1024x768x16x75) (rj-1024x768x16x85) (rj-1024x768x16x100) (rj-1024x768x16x120) (rj-1024x768x16x140) (rj-1024x768x16x144) (rj-1024x768x16x150) (rj-1024x768x16x170) (rj-1024x768x16x200) (rj-1024x768x16x240) (rj-1088x612x16x60) (rj-1088x612x16x70) (rj-1088x612x16x72) (rj-1088x612x16x75) (rj-1088x612x16x85) (rj-1088x612x16x100) (rj-1088x612x16x120) (rj-1088x612x16x140) (rj-1088x612x16x144) (rj-1088x612x16x150) (rj-1088x612x16x170) (rj-1088x612x16x200) (rj-1088x612x16x240) (1152x864x16x60) (rj-1152x864x16x70) (rj-1152x864x16x72) (rj-1152x864x16x75) (rj-1152x864x16x85) (rj-1152x864x16x100) (rj-1152x864x16x120) (rj-1152x864x16x140) (rj-1152x864x16x144) (rj-1152x864x16x150) (rj-1152x864x16x170) (rj-1152x864x16x200) (1280x720x16x60) (rj-1280x720x16x70) (rj-1280x720x16x72) (rj-1280x720x16x75) (rj-1280x720x16x85) (rj-1280x720x16x100) (rj-1280x720x16x120) (rj-1280x720x16x140) (rj-1280x720x16x144) (rj-1280x720x16x150) (rj-1280x720x16x170) (1280x768x16x60) (rj-1280x768x16x70) (rj-1280x768x16x72) (rj-1280x768x16x75) (rj-1280x768x16x85) (rj-1280x768x16x100) (rj-1280x768x16x120) (rj-1280x768x16x140) (rj-1280x768x16x144) (rj-1280x768x16x150) (rj-1280x768x16x170) (rj-1280x800x16x60) (rj-1280x800x16x70) (rj-1280x800x16x72) (rj-1280x800x16x75) (rj-1280x800x16x85) (rj-1280x800x16x100) (rj-1280x800x16x120) (rj-1280x800x16x140) (rj-1280x800x16x144) (rj-1280x800x16x150) (rj-1280x800x16x170) (1280x960x16x60) (rj-1280x960x16x70) (rj-1280x960x16x72) (rj-1280x960x16x75) (rj-1280x960x16x85) (rj-1280x960x16x100) (rj-1280x960x16x120) (rj-1280x960x16x140) (rj-1280x960x16x144) (rj-1280x960x16x150) (rj-1280x960x16x170) (1280x1024x16x60) (rj-1280x1024x16x70) (rj-1280x1024x16x72) (rj-1280x1024x16x75) (rj-1280x1024x16x85) (rj-1280x1024x16x100) (rj-1280x1024x16x120) (rj-1280x1024x16x140) (rj-1280x1024x16x144) (rj-1280x1024x16x150) (rj-1280x1024x16x170) (1360x768x16x60) (rj-1360x768x16x70) (rj-1360x768x16x72) (rj-1360x768x16x75) (rj-1360x768x16x85) (rj-1360x768x16x100) (rj-1360x768x16x120) (rj-1360x768x16x140) (rj-1360x768x16x144) (rj-1360x768x16x150) (rj-1360x768x16x170) (1600x900x16x60) (rj-1600x900x16x70) (rj-1600x900x16x72) (rj-1600x900x16x75) (rj-1600x900x16x85) (rj-1600x900x16x100) (rj-1600x900x16x120) (rj-1600x900x16x140) (rj-1600x900x16x144) (rj-1600x900x16x150) (1600x1024x16x60) (rj-1600x1024x16x70) (rj-1600x1024x16x72) (rj-1600x1024x16x75) (rj-1600x1024x16x85) (rj-1600x1024x16x100) (rj-1600x1024x16x120) (1600x1200x16x60) (rj-1600x1200x16x70) (rj-1600x1200x16x72) (rj-1600x1200x16x75) (rj-1600x1200x16x85) (rj-1600x1200x16x100) (rj-1600x1200x16x120) (1920x1080x16x30) (1920x1080x16x60) (rj-1920x1080x16x70) (rj-1920x1080x16x72) (rj-1920x1080x16x75) (rj-1920x1080x16x85) (rj-1920x1080x16x100) (1920x1200x16x60) (rj-1920x1200x16x70) (rj-1920x1200x16x72) (rj-1920x1200x16x75) (rj-1920x1200x16x85) (rj-1920x1200x16x100) (1920x1440x16x60) (rj-1920x1440x16x70) (rj-1920x1440x16x72) (rj-1920x1440x16x75) (rj-1920x1440x16x85) (rj-2048x1536x16x60) (rj-2048x1536x16x70) (rj-2048x1536x16x72) (rj-2048x1536x16x75) (rj-2048x1536x16x85) (rj-640x480x32x70) (rj-640x480x32x72) (rj-640x480x32x75) (rj-640x480x32x85) (rj-640x480x32x100) (rj-640x480x32x120) (rj-640x480x32x140) (rj-640x480x32x144) (rj-640x480x32x150) (rj-640x480x32x170) (rj-640x480x32x200) (rj-640x480x32x240) (rj-720x480x32x60) (rj-720x576x32x50) (rj-720x576x32x60) (rj-800x600x32x70) (rj-800x600x32x72) (rj-800x600x32x75) (rj-800x600x32x85) (rj-800x600x32x100) (rj-800x600x32x120) (rj-800x600x32x140) (rj-800x600x32x144) (rj-800x600x32x150) (rj-800x600x32x170) (rj-800x600x32x200) (rj-800x600x32x240) (rj-848x480x32x60) (rj-848x480x32x70) (rj-848x480x32x72) (rj-848x480x32x75) (rj-848x480x32x85) (rj-848x480x32x100) (rj-848x480x32x120) (rj-848x480x32x140) (rj-848x480x32x144) (rj-848x480x32x150) (rj-848x480x32x170) (rj-848x480x32x200) (rj-848x480x32x240) (rj-960x600x32x60) (rj-960x600x32x70) (rj-960x600x32x72) (rj-960x600x32x75) (rj-960x600x32x85) (rj-960x600x32x100) (rj-960x600x32x120) (rj-960x600x32x140) (rj-960x600x32x144) (rj-960x600x32x150) (rj-960x600x32x170) (rj-960x600x32x200) (rj-960x600x32x240) (rj-1024x768x32x70) (rj-1024x768x32x72) (rj-1024x768x32x75) (rj-1024x768x32x85) (rj-1024x768x32x100) (rj-1024x768x32x120) (rj-1024x768x32x140) (rj-1024x768x32x144) (rj-1024x768x32x150) (rj-1024x768x32x170) (rj-1024x768x32x200) (rj-1088x612x32x60) (rj-1088x612x32x70) (rj-1088x612x32x72) (rj-1088x612x32x75) (rj-1088x612x32x85) (rj-1088x612x32x100) (rj-1088x612x32x120) (rj-1088x612x32x140) (rj-1088x612x32x144) (rj-1088x612x32x150) (rj-1088x612x32x170) (rj-1088x612x32x200) (rj-1152x864x32x70) (rj-1152x864x32x72) (rj-1152x864x32x75) (rj-1152x864x32x85) (rj-1152x864x32x100) (rj-1152x864x32x120) (rj-1152x864x32x140) (rj-1152x864x32x144) (rj-1152x864x32x150) (rj-1152x864x32x170) (rj-1280x720x32x70) (rj-1280x720x32x72) (rj-1280x720x32x75) (rj-1280x720x32x85) (rj-1280x720x32x100) (rj-1280x720x32x120) (rj-1280x720x32x140) (rj-1280x720x32x144) (rj-1280x720x32x150) (rj-1280x768x32x70) (rj-1280x768x32x72) (rj-1280x768x32x75) (rj-1280x768x32x85) (rj-1280x768x32x100) (rj-1280x768x32x120) (rj-1280x768x32x140) (rj-1280x768x32x144) (rj-1280x768x32x150) (rj-1280x800x32x60) (rj-1280x800x32x70) (rj-1280x800x32x72) (rj-1280x800x32x75) (rj-1280x800x32x85) (rj-1280x800x32x100) (rj-1280x800x32x120) (rj-1280x800x32x140) (rj-1280x800x32x144) (rj-1280x800x32x150) (rj-1280x960x32x70) (rj-1280x960x32x72) (rj-1280x960x32x75) (rj-1280x960x32x85) (rj-1280x960x32x100) (rj-1280x960x32x120) (rj-1280x960x32x140) (rj-1280x960x32x144) (rj-1280x960x32x150) (rj-1280x1024x32x70) (rj-1280x1024x32x72) (rj-1280x1024x32x75) (rj-1280x1024x32x85) (rj-1280x1024x32x100) (rj-1280x1024x32x120) (rj-1280x1024x32x140) (rj-1280x1024x32x144) (rj-1280x1024x32x150) (rj-1360x768x32x70) (rj-1360x768x32x72) (rj-1360x768x32x75) (rj-1360x768x32x85) (rj-1360x768x32x100) (rj-1360x768x32x120) (rj-1360x768x32x140) (rj-1360x768x32x144) (rj-1360x768x32x150) (rj-1600x900x32x70) (rj-1600x900x32x72) (rj-1600x900x32x75) (rj-1600x900x32x85) (rj-1600x900x32x100) (rj-1600x900x32x120) (rj-1600x1024x32x70) (rj-1600x1024x32x72) (rj-1600x1024x32x75) (rj-1600x1024x32x85) (rj-1600x1024x32x100) (rj-1600x1200x32x70) (rj-1600x1200x32x72) (rj-1600x1200x32x75) (rj-1600x1200x32x85) (rj-1600x1200x32x100) (rj-1920x1080x32x70) (rj-1920x1080x32x72) (rj-1920x1080x32x75) (rj-1920x1080x32x85) (rj-1920x1200x32x70) (rj-1920x1200x32x72) (rj-1920x1200x32x75) (rj-1920x1200x32x85) (rj-1920x1440x32x70) (rj-1920x1440x32x72) (rj-1920x1440x32x75) (rj-1920x1440x32x85) (rj-2048x1536x32x60) (rj-2048x1536x32x70) (rj-2048x1536x32x72) (rj-2048x1536x32x75) (rj-2048x1536x32x85)
    directinput: searching joystick=found (3 axes, 1 buttons)
    tmgl: loading font v2 texture/arial8b.tmf=(256x256) (32x255) ok
    tmgl: loading font v2 texture/arial20b.tmf=(256x256) (32x255) ok
    sim: loading scenery scenery/forestlake.geo...
    sim: 2 objects 0 dynobjects
    sim: start position 1
    sim: start position 2
    sim: start position 3
    sim: ballons=10 (80.00,128.00,4.00) (105.00,152.00,8.00)
    sim: dragrace=(100.00,180.00)
    sim: spotarea=(20.00,14.00)
    sim: pylon 1=(-40.00,140.00,-1.00)
    sim: pylon 2=(110.00,125.00,-1.00)
    sim: pylon 3=(110.00,155.00,-1.00)
    sim: loading ground scenery/forestlake/forestlakef.obj
    sim: loading object scenery/forestlake/forestlakeg.obj=ok
    sim: loading object scenery/forestlake/forestlakeo.obj=ok
    sim: 389 transparent geometries 388 billboards
    sim: loading time=899282 mus
    tmcollision: 4223 triangles using 185812 bytes
    tmcollision: 388 billboards
    tmcollision: omin=(-7819.9,-8338.1,-0.0) omax=(8016.8,8285.5,471.0)
    tmcollision: octmin=(20.0,20.0,20.0)
    tmcollision: otnodes=2297 otdepth=26
    tmcollision: otnmaxareas=79 otnavgareas=4 otnminsize=(15.466,16.234,14.718)
    tmcollision: otareas=9990 mem=559440
    tmcollision: otclppl=36517 mem=1168544
    tmcollision: 2297 octrees, using 597220 bytes
    tmcollision: total mem=2511016 bytes
    tmcollision: time=301542mus
    tmcolldynamic: no dynamic objects or triangles
    tmgl: failed to load texture texture/water2.tmt
    tmgl: failed to load texture texture/water1.tmt
    sim: loading aircraft 1 extra330s...
    tmdairfoil: loading naca0015 ok
    directsound: register sound sound/extra330s-1710.wav=ok
    directsound: register sound sound/extra330s-3510.wav=ok
    directsound: register sound sound/extra330s-5730.wav=ok
    generating shadow extra330sshadow0=(generating fast shadow map)radius=2.98 bbmin=(-1.65 -1.65 -0.53) bbmax=(1.65 1.65 0.49)
    sim: creating blurr=Propeller
    tmmusic: play single song 0
    tminput: searching for input devices...
    tminput: checking for transmitter on comport 1=found, but no signal, t=5
    tminput: checking for transmitter on comport 2=(receiving) none
    tminput: closing comport
    tminput: checking for transmitter on comport 3=createfile failed
    tminput: checking for transmitter on comport 4=createfile failed
    tminput: checking for transmitter on comport 5=createfile failed
    tminput: checking for transmitter on comport 6=createfile failed
    tminput: checking for transmitter on comport 7=createfile failed
    tminput: checking for transmitter on comport 8=createfile failed
    tminput: 1 devices found
    tminput: checking for joystick=3 axes 1 buttons
    tminput: 2 devices found
    loading input device calibration config/radio0.tmc=ok
    loading input device calibration config/joystick.tmc=ok
  • Flappsohr
    • 02.05.2005
    • 1034
    • Tugrul
    also Hut ab sehr genaue Beschreibung mit entsprechendem Log
    Ich hatte sehr ähnliche Probs mit meiner Schleuder, AFPD und den eben neuesten Treibern, ein Mitglied aus dem Forum empfahl die Omega Treiber (Treiber die bei spez Apps keine Probs verursachen- hat mein Problem behoben, kann ich auch Dir empfehlen, mußt Deine Graka suchen (weis nicht ob es nur Radeon Treiber gibt?).
    Hier der Link zum Fred.
    Habe die Seite grade beim Testen nicht erreicht, vielleicht Server down?
    Viel Glück, Gruß Tugrul 8)
