Easyfly3 Modelle?
  • fifi
    fifi
    Easyfly3 Modelle?
    Wisst ihr, was es für Modelle bei Easyfly 3 gibt ? (Die version für ca 80€ mit 30 Modellen FLUGSIMULATOR EASYFLY 3 GAMECOMMANDER im Conrad Online Shop )
  • Samanosun
    • 12.08.2010
    • 70
    • Reinhold
    • Wien
    AW: Easyfly3 Modelle?
    Das findest du hier auf der Homepage:
    31 aircraft models included:
    A6texan - Model of the popular WW2 Trainer
    Adrenaline120 - The -all purpose- aerobatic model
    AH64 Apache - The ruler above the battle field
    Chinook 53 Hubschrauber - a large scale helicopter with retracts
    Cularis - Allround performer at the slope, in thermal lifts and for aerobatics
    DA40 - Modern single engine sports plane
    EC135 - Highly detailed model of the multi-purpose helicopter
    Eco7 - A very beautiful entry level helicopter for 7-10 cells
    Eco8 - (IKARUS) Proven performer since many years!
    Edge540 - 2-Meter TOC model for ultimate aerobatics and 3D flight
    Extra330s: - The aerobatic machine for the PROs.
    F22 - Turbine powered model of the most advanced stealth fighter
    F84 -A jet from the beginning of the turbine age
    Fauvel -Scale model of the oldtimer flying wing
    Giles202toc - The machine for the most extreme model aerobatics
    Heli60 - The ultimate 3D helicopter
    Hercules -Model of the well known transporter with 4 x bold power
    Jungmeister -Aerobatic biplane, not only popular as a model
    Lama -The well proven IKARUS coax helicopter
    L39 -the Estern-block states Czech jet trainer
    LS8 Segler - LS8 Glider - (a beatuiful thermal glider)
    MD900 -NOTAR scale model helicopter
    Minimoa -True to scale model of the popular glider oldie
    PiccoloV2 - A beatiful micro helicopter from IKARUS
    PT40 Trainer - A perfect airplane for the novice
    Shock330s - Shocky 330S - The absolute indoor fun airplane!
    Shock4pps - Shocky4PPS - (the ultimate indoor machine for aerobatics and 3D performance)
    Superdimona -The motor glider for relaxed flying
    Trainer - Typical novice model with well-mannered flying characteristics
    Viper90 (IKARUS) -3D-Helicopter - no problem - even electric powered!
    Zlin50 -Attractive scale model of the Polish aerobatic machine
    8 unique airfield sceneries, including 7 breath-taking realistic 360 degree photographic
    Ich kann dir aber nicht sagen ob es Modelle irgendwo zum runterladen gibt. Bei zb. Phönix ist dies nicht möglich.
    Hier findest du noch einen tollen Thread bzgl. dem Vergleich von dem Simulatoren. Soweit ich da lesen kann gibt es wohl andere Modelle (zumindestens für die Version 4) aber die sind kostenpflichtig
    p.s. Seite 3 hast nen link zu nem direkten Vergleich
    Gruß Reinhold
    Zuletzt geändert von Samanosun; 04.08.2011, 17:11.
    Sender DX8
    T-REX 450 Pro; Blade MCPX V2; Blade MQX; Blade MSRX
    • fifi
      fifi
      Vielen Dank für die Liste,
      Gibt es unter den aufgeführten Modellen einen Heli, der mit dem Blade 450 vergleichbar ist?
      • Samanosun
        • 12.08.2010
        • 70
        • Reinhold
        • Wien
        sorry bin ich überfragt, vllt kann das jemand beantworten der den Sim hat.
        Sender DX8
        • fifi
          fifi
          Egal... Ich werde ihn mir einfach in nächster Zeit kaufen. Die Premiumversion kommt wegen dem hohen preis von ca 280€ sowiso nicht in Frage.
          • Heigei88
            Heigei88
            gibt es beim Easyfly 3 nicht, hab auch die "Vollversion" aber die verstaubt im Regal...^^
