Anfänger aus Oberfranken - Blade MPC X V2 + Zubehör?
AW: Anfänger aus Oberfranken - Blade MPC X V2 + Zubehör?
Also würdest du sagen das der Nano QX unterhalb des MQX angesiedelt ist?An einen MQX solltest du also erst denken, wenn du mit dem NQX im agilen Modus Rundflüge schaffst.Spektrum DX6i - MCPX V2 - Nano QX - MQX - 300X
Einstellungen hab ich aktuell diese hier:
Blade Nano QX Heli Profile
Thanks goes out to pfloyd, whose post about dx6i settings for mcx2 was used to template this.
Thanks also to rkweekly, who inspired me to make these notes with his initial work on finding the differences in settings.
Please keep in mind I'm not an expert, just a guy who saw an opportunity to share what I learned here for the benefit of others. Contribute and/or correct if you find something that doesn't work right, or something that works BETTER!
These settings are now as final as I can get them, they have been updated 6/20/13 following a majority of the conversation below. You do not need to read the whole conversation to get the proper settings, they are in this post.
SETUP LIST
Model Type
Heli
REVERSE
THRO - N
AILE -N
ELEV - N
RUDD - N
GYRO - N
PITCH - R
Swash Type
90*1 servo
D/R Combi
D/R SW: ELEV
Adjust List
D/R & EXPO
With Elevator D/R switch in position 0
AILE 0 70% INH
ELEV 0 70% INH
RUD 0 70% INH
With Elevator D/R switch in position 1
AILE 1 100% INH
ELEV 1 100% INH
RUDD 1 100% INH
Travel ADJ
THRO - 100% - 100%
AILE - 100% - 100%
ELEV - 100% - 100%
RUDD - 100% - 100%
GYRO - 100% - 100%
PITC - 100% - 100%
Throttle CUR
NORM
pos L 0.0%
pos 2 25.0%
pos 3 50.0%
pos 4 75.0%
pos H 100.0%
STUNT
pos L 0.0%
pos 2 25.0%
pos 3 50.0%
pos 4 75.0%
pos H 100.0%
HOLD
pos L 0.0%
pos 2 0.0%
pos 3 0.0%
pos 4 0.0%
pos H 0.0%
Pitch CUR (This is only used as a toggle to switch flight mode between stability and agility for this model)
NORM
pos L 0.0%
pos 2 0.0%
pos 3 0.0%
pos 4 0.0%
pos H 0.0%
STUNT
pos L 80.0%
pos 2 80.0%
pos 3 80.0%
pos 4 80.0%
pos H 80.0%
HOLD
pos L 0.0%
pos 2 0.0%
pos 3 0.0%
pos 4 0.0%
pos H 0.0%
MIX 1
INH
MIX 2
INH
Revo Mix
INHSpektrum DX6i - MCPX V2 - Nano QX - MQX - 300X
Wildfliege(r)
Der nqx und mqx sind eigentlich fast gleich, nur hat der kleinere noch den stabilen Modus. Im agilen Modus fliegt er etwa so wie der mcp x, den du ja schon hast.
Nur kannst du keinen Kunstflug, sondern nur Flips fliegen.
Also beim den Quads.
Cybershadow
Dreht der Nano bei Vollgas eigentlich auch weg wie der mQX, oder steigt er halbwegs senkrecht?
Das liegt am Downwash..
Der NQX ist agiler als der MQX.
Der MQX ist gemütlicher zu fliegen, hat aber keinen Stabilitäts-Modus der einiges zu Beginn erleichtert.
AnselmDevo 8s / DX6i
Blade 300x / MQX / NQX
Protos 500 / MiniProtos
Wobei der MQX bei entsprechender Einstellung schon ziemlich agil ist. Ich fliege ihn jetzt drinnen immer mit maximalen Einstellungen an der Funke. Also Dualrate auf allen Achsen 100%, Traveladjust 125% und 30% negativem Expo. Damit ist er auf 3 mal 3 Meter schon ganz schön fordernd.
RaimundXK K124 EC145, Protos 500, 450ger Jet Ranger
Walkera Devo10
Sim:Clearview, Heli-X
Ich wollte mir ja für den MCPX mal farbige Rotorblätter kaufen, jetzt hab ich gesehen das es für den BL 2 unterschiedliche Durchmesser gibt, gehen die beim normalen auch? Welchen sollte man da wählen? Die 115mm Hauptrotorblätter werden zu groß sein ?
Mir wurde ja dazu geraden die Blätter mit den Knubbel zu montieren, kann mir da jemand die technischen Unterschiede zu den normalen Blättern erklären? Wie sind Lynx Blätter oder sollte man eine andere Marke bevorzugen?Zuletzt geändert von p00nage; 08.07.2013, 08:51.Spektrum DX6i - MCPX V2 - Nano QX - MQX - 300X
Quax2012
Der BL ist vom Motor/Akku her ein ganz anderes Kaliber...
Hat der Hersteller/Händler nix angegeben, ob die für den V2 passen?
Meine Blätter (Lynx) haben 11cm Blattlänge (über alles).
Ein halber cm mehr... wäre evtl. auch noch machbar.
Die Frage ist vielleicht eher: Passen die Blattwurzeln auch in die Blatthalter?
Ich weiß nur nicht, ob's dem Motor/Akku nicht zuviel wird -
der geht bei meinen Blättern schon manchmal etwas in die Knie (Drehzahlmäßig).
Evtl. mußt Du dann TravelAdjust für Pitch etwas reduzieren (ich hab derzeit 80% drin).
Meine Lynx-Blätter sind ok. Als Anfänger merkst Du da keinen großen Unterschied zwischen den verschiedenen Fabrikaten, würd ich sagen. Microheli hatte ich auch schon drauf. Hielten nicht lange, war beim dem Crash letzt aber auch kein Wunder. Da hätten andere vermutlich auch die Grätsche gemacht.
Allerdings flieg ich die ohne Knubbel. Die mit Knubbel sind Trainigsblätter.
Der Heli ist dann etwas ruhiger und nicht so agil (wurde mir zumindest erklärt).
Da ich vorher schon Erfahrung mit nervösen Helis hatte (mSRX),
hab ich damals allerdings die ohne Knubbel drauf gelassen. Kam gut damit zurecht,
also bin ich dabei geblieben...Zuletzt geändert von Gast; 08.07.2013, 09:06.
BL: Blade MCPX BL - RC-NOW Modellbau Esky Walkera Eflite Align TRex Futaba Shop Seite 3
MCPX: Blade mcp X - RC-NOW Modellbau Esky Walkera Eflite Align TRex Futaba Shop
Beim BL gibt es eben noch die passenden Heckrotoren, was mich aber stutzig macht ist das es dort 2 Durchmesser gibt. Auch gibt´s beim BL die Hauptrotorblätter mit Knubbel, deswegen wüsste ich gern wo die Unterschiede liegen. Da ich ja erst am Anfang vom Rundflug bin, muss des ganze auch nicht so agil sein ;-)Spektrum DX6i - MCPX V2 - Nano QX - MQX - 300X
Quax2012
Der erste Link ist BL. Beim Heck zwei verschiedene Heckrotoren - da hast Du recht. Ich denk mal, dass der standardmäßig den kleineren Heckrotor hat, aber bei extremen Manövern auch wieder an seine Grenzen kommt (wie der V2). Dafür dann der größere Heckrotor. Wenn's der Heckmotor mitmacht und es vom Platz her paßt, kein Problem. ßhnlicher Effekt wie ein längeres Heckrohr.
Das zweite sind die V2-Blätter. 105 mm paßt von Lochmitte bis außen gemessen. 110 mm über alles.
Wegen Knubbel oder nicht: Du hast ja original beide dabei. Wenn Du den Unterschied wissen willst, Probier die doch einfach mal gegeneinander aus
. Letztlich mußt Du selber sehen, was Dir am Besten liegt.
Zuletzt geändert von Gast; 08.07.2013, 09:18.
Naja ich bin am Anfang ja die ohne Knubbel "geflogen" und dann wurde mir zu den mit Knubbel geraten, wüsste halt gern wo theoretisch der Unterschied liegt ;-)Spektrum DX6i - MCPX V2 - Nano QX - MQX - 300X
Itzehoer
Mit Knubbel etwas stabiler im Flug.Hab neulich die Bl blätter auf dem normalen gehabt. Legt in der Steigleistung gut zu, dreht aber mit dem langen Heck schon leicht weg. Dann also mit pitch runter und somit relativiert sich der Effekt.
Ok bei den BL Blättern ist die Auswahl halt größer ^^ Die unterschiedlichen Heckrotoren hast du nicht auch zufällig getestet?Spektrum DX6i - MCPX V2 - Nano QX - MQX - 300X
