The OS max 91 HZ-R
First production is scheduled to be complete in early March.
Here are features.
- This is a main fuel tank pressurized regulator system integrated version of the 91HZ.
- Newly designed 61E Carburetor integrated with a regulator surely regulates pressurized fuel. As with other 91HZ engines,
it features twin needles which can adjust hovering and high speed flight independently.
- Regulator is located at a place where heat does not suffer and access is easier.
- The system ensures stable fuel supply irrespective of rapid model attitude and G changes.
- The system does not use muffler pressurized fuel system which requires needle adjustment according to the change of muffler pressure.
Conversion Set consists of Carburetor integrated with regulator, Back plate fitted with a pressure nipple and check valve.
MOTOR SPECS.
Displacement : 14.95cc (0.912cu.in)
Bore : 27.7mm (1.091in)
Stroke : 24.8mm (0.976in)
Weight : 625g (22.05oz)
Output : 3.4ps/15,000r.p.m.
