Omphobby M7R
  • MrMikeBravo
    • 10.04.2023
    • 199
    • Kilian
    Omphobby M7R
    Der M7 wurde von OMP überarbeitet:
    Introducing OMPHOBBY M7R - Engineered for Champions!
    In late 2023, OMPHOBBY redefined the 700 game with the introduction of the M7. A helicopter that, from the get go, has proven to be virtually bullet proof, indestructible in the air, and to this day, delivers a flight performance that could immediately compete at the very top, delivering world-class performance. With its incredible presence in the air, superior flight characteristics, ultra-quiet drivetrain, extremely easy maintenance, and tool-free adjustable belt drive, M7 has quickly become the favorite helicopter of its class for countless pilots around the world.
    Now, two years later, we’re back to refine the M7 into its ultimate competition form, upgraded with everything we have learned in helicopter development to this point: This is M7R, one helicopter to rule them all!
    M7R’s primary focus lies in zero-compromise weight optimization. While the core structure remains an M7 at heart, many parts have been thoroughly optimized and refined. Countless hours of careful FEA simulation have allowed us to shave 200 grams off the M7R airframe compared to M7, without compromising durability and performance in flight. This substantial leap makes M7R one of the lightest, lowest-inertia, fully-fledged 700 class helicopters on the market, ready to take anything you could throw at it in even the toughest competition. Engineered for Champions!
    At the heart of every RC helicopter lie its rotor systems. Since its release, the M7 has set the benchmark with one of the cleanest, most precise, yet remarkably expansive and powerful flight performances on the market, and M7R will build on this achievement further. M7R will come with the same, great 32mm main rotor geometry that M7 used - retaining the same direct, linear and crisp control feel customers around the globe have come to love, all in a much sleeker and more elegant rotor head. M7R will be equipped with POM rotor head inserts by default, which allow for extraordinarily crisp control response and stability from down low at 1100 RPM, all the way up to 2400 RPM! For those who can’t ever have enough control power, an optional 1:1 rotor geometry will be available at a later time.
    No single main rotor is complete without an exceptional tail, which the M7 has delivered from day one. From its inception, the M7 tail assembly and belt drive have proven to be flawless and virtually indestructible in flight. M7R will proudly carry this legacy forward by retaining the M7’s trusted tail assembly, with only a few, yet notable upgrades: M7R’s tail rotor dampers are now made from a new, vastly more durable material, which not only greatly extends their service-life, but also increases tail control precision and response further by guiding the tail rotor disk more tightly. Additionally, the tail fin and tail boom are now silk screen printed, removing the need for the user to apply stickers to them.
    The M7R transmission is built around our new, heavy-duty 122t main gear and matching 13t pinion, creating a bullet-proof drivetrain, ready for even the biggest motors and most demanding competition flights. Available pinions range from 11t to 15t, so you can always find the optimal gear ratio for your specific power system. The tail rotor ratio remains the proven 5:1, using the same 8mm belt and pulleys, tensioned by our helically driven belt tensioner. Where others lose teeth or require tools to adjust, M7R keeps going strong!
    A new lower frame, utilizing chamfered carbon panels and precision-machined aluminium battery rails, guarantees smooth battery insertion and removal every time. The change to flat plates opens up even more space for the biggest and heaviest batteries out there, as demanded by competition pilots of modern times. While this measure not only reduces the weight of the lower frame further compared to the previously used, molded carbon panels, it also simplifies maintenance and reduces repair cost for the user in the event of a rapid unscheduled disassembly. For those who prefer to retain the original look, the M7’s molded lower frame panels can still be adapted to M7R with only minimal modification, as all mounting points remain the same.
    The M7R’s revised tail boom clamping system keeps both the upper and lower frames perfectly aligned, while delivering maximum tail boom clamping force in any situation, even at the absolute edge of the flight envelope. The design now allows for removal of the entire lower frame while keeping the tail boom clamped, and likewise, the tail boom can now easily be removed without loosening a single screw on the lower frame.
    For our new flagship helicopter, we take pride in using only the most excellent materials. All highly loaded or rotating aluminum parts will be precision-machined from the same, extremely durable 7075 alloy we used on M7, while all remaining aluminium parts will continue to be made from high-quality 6061 T6 alloy. These choices guarantee exceptional durability and longevity in flight, in crashes and during maintenance.
    M7R brings our sleeker, lighter and more aerodynamic, canopy designs to the 700 class, including their superior flexibility and a much more durable paint coat. This new canopy follows the design philosophy of all modern OMPHOBBY canopies and effectively reduces the helicopter’s drag, allowing it to reach higher top speeds, and simplifies battery changes greatly, as it is much easier to remove and install. At launch, M7R will feature the four signature colors of M5 and M6: Cosmic Orange, Solar Yellow, Nebula Pink, and Aurora Green. More colors will follow at a later time!
    While M7R has been optimized to the max, the airframe still retains all key component interfaces, ensuring exceptional parts compatibility and upgradeability with the original M7.
    This allows you to upgrade an M7 to M7R gradually, and in a pinch, many M7 components will still fit and function on the M7R.
    Flying the M7R, you will immediately notice the reduced weight and inertia of the model compared to the M7. Collective pitch moves the helicopter powerfully, yet with amazing precision and ease. Cyclic commands are executed more quickly, more precisely, more quietly, faster, and almost completely effortlessly, thanks to the reduced moments of inertia. Directional stability, resulting from requiring less main rotor blade angle to maneuver, is rock solid, and tail control is razor-sharp and ultra-precise.
    Zuletzt geändert von thomas1130; 20.08.2025, 14:02.
  • heli56
    • 05.04.2007
    • 3443
    • Toni
    • Hof / Pößneck
    Hoffe die Farbigen Heckrohre bleiben erhalten.
    • Leroy
      • 04.01.2015
      • 1015
      • Leo
      • MG Urdorf (CH)
      Eines der besten Sprüche, die ich gelesen habe:
      Ich kannte ja bis jetzt diese Springbäume etc, aber das ist schon noch eine Stufe besser
      • Johnny
        OMPHOBBY
        • 27.11.2010
        • 5671
        • Jonas
        Definitiv. Das Heckrohr ist identisch zum M7, also kannst du prinzipiell die bereits bestehenden Rohre nutzen.
        Ich denke, wir werden für den M7R wie beim M5 und M6 auf lackiertes Carbon gehen statt Alu, der Performance wegen.
        Jonas
        • Madness
          • 17.08.2008
          • 2700
          Auch wenn ich die Seitenteile des M7R als „Platten“ nicht so schön finde wie die alten des M7 ist es schön zu lesen das es möglich ist einen M7 per Teile Upgrade auf einen M7R aufzurüsten. Sofern man das vollumfänglich möchte.
          Schön das der Support für Spare Parts des M7 erhalten bleibt.
          • Johnny
            OMPHOBBY
            • 27.11.2010
            • 5671
            • Jonas
            Der Wegfall der geformten Seitenteile ist im Sinne der Gewichtsoptimierung, und weil Wettbewerbspiloten mittlerweile noch mehr Platz für dickere Akkus brauchen. Du kannst aber auch mit minimaler Modifikation die Formteile vom M7 am M7R verbauen, so sind wir die ersten Prototypen auch geflogen, ist dann eben nur etwas schwerer. Ansonsten sind alle M7R Teile direkt an M7 anbaubar, und nur sehr wenige Teile müssen tatsächlich als Gruppe verbaut werden, wenn man upgraden will. Das werden wir dann auch alles genau in der Anleitung aufschlüsseln.
            Jonas
            • sme
              sme
              • 21.02.2008
              • 868
              • Düsseldorf
              Hallo Johnny,
              gibt es schon einen Preis und ein Datum wann die neue Version verfügbar sein wird?
              Der Orangene kriegt hoofentlich wieder schwarze Kufen.
              Stefan
              "Wenn man keine Ahnung hat, einfach mal die Klappe halten."
              • Johnny
                OMPHOBBY
                • 27.11.2010
                • 5671
                • Jonas
                Zitat von sme Beitrag anzeigen
                Hallo Johnny,
                Ja, hat der Admin aber sehr schnell aus dem OP entfernt, also werde ich sie hier auch nicht posten. Zu finden auf Facebook und Instagram.
                Nein, aber die Kufen sind die gleichen wie am M7, nur mit etwas gekürzten Rohren. Kannst du umbauen, wie du möchtest.
                Jonas
                • sme
                  sme
                  • 21.02.2008
                  • 868
                  • Düsseldorf
                  Danke, habe es gefunden.
                  Wird es dann nur ein lackiertes Rohr geben, oder habe ich das falsch verstanden?
                  Paßt auch die etwas weichere Kopfdämpfung von der alten Version?
                  Die funktioniert ja bei niedrigeren Drehzahlen und nicht 3D besser?
                  Stefan
                  • goone75
                    • 20.06.2012
                    • 3736
                    Hoffen wir mal, dass die Haubenqualität dabei auch einen Sprung gemacht hat...
                    • Johnny
                      OMPHOBBY
                      • 27.11.2010
                      • 5671
                      • Jonas
                      Heckrohr ist standard Carbon, der Schriftzug wird aufgedruckt sein.
                      Gummidämpfung passt, aber das sind dann Bereiche unter 1100 RPM wo man die braucht, und da ist fast niemand unterwegs. Ich fliege z.B. 1400 mit POM ohne Probleme.
                      Zu den Hauben: Lest doch erstmal den Text, bevor ihr Kommentare abgebt.
                      Zuletzt geändert von Johnny; 20.08.2025, 17:45.
                      Jonas
                      • Madness
                        • 17.08.2008
                        • 2700
                        In dem Abschnitt steht eigentlich alles zur Haube:
                        M7R bringt unsere schlankeren, leichteren und aerodynamischeren Haubendesigns in die 700er-Klasse, einschließlich ihrer überlegenen Flexibilität und einer deutlich haltbareren Lackierung. Diese neue Haube folgt der Designphilosophie aller modernen OMPHOBBY-Hauben und reduziert effektiv den Luftwiderstand des Helikopters, wodurch er höhere Höchstgeschwindigkeiten erreichen kann. Zudem vereinfacht sie den Batteriewechsel erheblich, da sie sich deutlich einfacher entfernen und installieren lässt. Zum Start wird M7R in den vier charakteristischen Farben von M5 und M6 erhältlich sein: Cosmic Orange, Solar Yellow, Nebula Pink und Aurora Green. Weitere Farben folgen zu einem späteren Zeitpunkt!
                        • *wt98*
                          Optipower
                          Teampilot
                          • 13.02.2015
                          • 1614
                          • Italy
                          Cool dass man den M7 weiter optimiert, gefällt mir gut!
                          make it better, fly with OptiPower
                          • Undangerous_3D
                            • 11.11.2012
                            • 958
                            • Norbert
                            • HCHH Stemwarde, Barsbüttel
                            Passen dann die M7R Seitenteile und die Haube dann auch auf den alten M7 ? Und sind die Endkappen der Weißen Kufen endlich aus Weißen Kunsstoff, jetzt ist es ja so das der Lack Abplatzt und da der sehr unschöne Schwarze Kunststoff durch schaut
                            Zuletzt geändert von Undangerous_3D; 20.08.2025, 19:49.
                            • Johnny
                              OMPHOBBY
                              • 27.11.2010
                              • 5671
                              • Jonas
                              Ja und ja. Die Kappen sind jetzt die gleichen wie am M5, aus weißem Plastik.
                              Wie gesagt, genaue Kompatibilitäten werden in der Anleitung aufgeführt sein. Die schreiben wir gerade.
                              Jonas
