YouTube
Weight (no battery/fuel)
4100 g
â?¢ Light canopy, boom, low frames as for SG741
â?¢ New graphic scheme, very aggressive, obtained with a new process which adds so many details
â?¢ New main and tail rotor obtained as a mix between old HUB and new blade grip, used on Kraken
â?¢ New blades 690 mm produced with a new process that optimizes the final weight.
â?¢ Power train full enclosed in aluminum case.
â?¢ Independent belt shafts for the transmission and the tail.
â?¢ Ultra-light Tail case with quick tail fin replacement.
â?¢ Full body and boom design with integrated frames.
â?¢ Boom detachment system for improved crash durability.
Goblin Kraken introduce again many original solutions never saw in RC Heli worldâ?¦
Kit Includes:
â?¢ Motor pulley 21T (other pulley sizes available)
â?¢ 2 sets battery tray with strap
â?¢ New SAB blades and tail blades ( 690 3 TBS + 115 3 TBS )
MAIN FEATURES:
TRANMISSION MODULE
â?¢ Power train support 3 shafts: Main shaft to the rotor, shaft to the motor, shaft to the tail.
â?¢ One-way system inside the Module
â?¢ Reliable, suitable for transmitting any power, it does not require maintenance.
â?¢ Sturdy in case of crash. It is possible to replace the main shaft by removing a single screw.
â?¢ The transmission module is supplied assembled and verified, ready to be used.
FEATURES
â?¢ The blade grips are made from 7075 T6 Aluminum and the blade grip arms are made from 6061 T6 Aluminum. In a crash you can bend the arm, but you will never damage the blade grip. Using 1x M4 screw makes it very easy to replace just the arm.
â?¢ Independent belt shafts for the motor transmission and the tail.
â?¢ Ultra-light tail case with quick tail fin replacement, 3 mm full carbon side plate, 23 grams lighter than the Thunder tail case. Very simple, strong, reliable & durable
â?¢ Kraken ESC support composite tray with sacrificial plastic insert. The edges are covered in rubber for protection...ESC wires are happy:-)
â?¢ Wire Support for super east wiring.
â?¢ Battery tray.
â?¢ Serial Number.
â?¢ Goblin Kraken High-tech composite carbon and airex sandwich.
GOBLIN KRAKEN 3 BLADES | Goblin Helicopters
vom Scheme her gefällt er mir besser wie der Edeka wäre das rot noch weg wäre es Perfekt!
Der Preis ist ok für den 3 Blatt 1199€
Release 30.04.20
was fast keiner fliegt
