Castle service advisory 2012 !!!
  • Aerodeck
    • 24.07.2010
    • 1030
    • Ralf
    • Kleinenbroich
    Das hatte ich gerade im Postfach !!!
    Inspection & Corrective Action Notice
    May 15, 2012
    ICE2 160HV ICE 200 Hydra ICE 240 Mamba XL Hydra ICE 200HV
    It has come to our attention that some of these ESCs which shipped since the August 2011 recall on the ICE HV, Mamba XL and Hydra Ice may experience failures due to the control board becoming unseated from the power board. This includes controllers that were repaired or replaced in response to the recall. This only applies to the controllers listed above. It does not apply to all ICE2HV controllers.
    The controllers listed above were built using two different plastic shell assemblies over the course of their production. Castle originally used two end caps that snapped around the heat sink halves and are held in place with adhesive labels. We switched to a newer plastic shell that was held together by four screws. The type of plastic shell used dictates the means of retaining the controllers' control board in its socket on the power board.
    As we made every effort to repair and return the exact controllers that we received in response to our August 2011 recall, units shipped back to customers may use either plastic assembly. The 4 screw clamshell case may leave enough space between the control board and the metal heat sink for the control board to become unseated from the power board. Castle has an easy to install means of ensuring the control board stays seated in the units built with the clamshell design; installation of a small piece of silicone-rubber foam to maintain a slight compression of the boards.
    All new controllers made and shipped during the period of August, 2011, to May 10, 2012, with the clamshell plastic should be assumed to need a foam keeper installed before any attempt is made to power or use the controller in any way.
    Click here to view complete instructions of the inspection procedure may be found on our website.
    Castle will provide users with the special foam at no charge. Please use the email form on the web page listed above to send us your mailing address and we will get the foam out to you immediately.
    Our records indicate that there are still quite a few controllers covered by the August 2011 recall that have not been returned to us for updating. Our conversations with customers at events around the country all seem to indicate that many of you were waiting until our service wait time was reduced in order to receive your repaired controller in the shortest possible time. Please be advised that our return time on these units is now generally a matter of a few days.
    Please do not use controllers covered by the August 2011 advisory that have not been updated to ICE2, Hydra ICE2, or Mamba XL2 status. Send them in to Castle using the procedure outlined on the advisory page so that we can update them.
    We apologize for any inconvenience any of these issues may cause you, and we sincerely appreciate your business.
    We look forward to regaining your trust in our products and our company.
    Regards,
    Team Castle
    Wiedergeburt meiner Bell 222 - 90
  • bluesky
    • 18.08.2010
    • 2294
    • Felix
    • Wild, Lohe-Föhrden
    AW: Castle service advisory 2012 !!!
    Da werd ich wohl den Regler bearbeiten müssen. Bei mir ist nichts von einem roten Punkt zu sehen.
    Beste Grüße
    Felix
    GruÃ?
    Felix
    • Aerodeck
      • 24.07.2010
      • 1030
      • Ralf
      • Kleinenbroich
      Einen roten Punkt habe ich auch nicht, aber weiter habe ich noch nicht geschaut.
      Das fehlte noch im ersten Post. > Castle Creations - Service Advisory <
      • bluesky
        • 18.08.2010
        • 2294
        • Felix
        Ich hab erstmal diesen Schaumstoff bestellt. Werde ihn auch erst aufmachen, wenn ich das habe. Bis dahin, werde ich aber noch normal fliegen gehen.
        Beste Grüße
        Felix
        GruÃ?
        Felix
        • Aerodeck
          • 24.07.2010
          • 1030
          • Ralf
          • Kleinenbroich
          dito...
          • Aerodeck
            • 24.07.2010
            • 1030
            • Ralf
            • Kleinenbroich
            Ich habe meinen Regler mal eben demontiert , aber ich Frage mich was das gute bringen soll ??
            *edit* Hat sich erledigt, bei näherer Betrachtung erschlisst es sich .
            Zuletzt geändert von Aerodeck; 16.05.2012, 16:15.
            • Madness
              • 17.08.2008
              • 2700
              Na zum Glück sind die 120HV und 80HV nicht wieder betroffen. Sonst hast wieder die die A-Karte bei allen Align Combo´s
              • Aerodeck
                • 24.07.2010
                • 1030
                • Ralf
                • Kleinenbroich
                Das ist wohl war. Trotzdem Frage ich mich warum die nicht direkt das blöde Pad montiert haben. Das kostet nichts und bringt viel. Selbst ich als Laie erkenne das sich das Control Board unter Umständen bei einer starken Belastung aus dem Steckplatz lösen könnte.
                • Jense
                  Jense
                  Naja, wenigstens nicht einschicken.
                  Postet bitte jemand bilder vom `update`?
                  THX
                  • bluesky
                    • 18.08.2010
                    • 2294
                    • Felix
                    Mein Pad wurde gestern verschickt. Allerdings haben die es nach New Zealand geschickt! Ich könnt k.....
                    Beste Grüße
                    Felix
                    GruÃ?
                    Felix
                    • Aerodeck
                      • 24.07.2010
                      • 1030
                      • Ralf
                      • Kleinenbroich
                      Beste Grüße
                      Felix
                      Hast du eine Mail von denen bekommen ??
                      • bluesky
                        • 18.08.2010
                        • 2294
                        • Felix
                        Ja, hab ne Versandbestätigung mit Track- and Tracenumber erhalten. Naja, bin mal gespannt wann ich das Pad erhalte.
                        Beste Grüße
                        Felix
                        GruÃ?
                        Felix
                        • Aerodeck
                          • 24.07.2010
                          • 1030
                          • Ralf
                          • Kleinenbroich
                          Na Super , ich bekomme mal wieder nix .
                          • bluesky
                            • 18.08.2010
                            • 2294
                            • Felix
                            Naja, wirst sicherlich Montag ne Mail bekommen. War ja auch ein Feiertag und wahrscheinlich eine größere Nachfrage.
                            Beste Grüße
                            Felix
                            GruÃ?
                            Felix
                            • Aerodeck
                              • 24.07.2010
                              • 1030
                              • Ralf
                              • Kleinenbroich
                              Heute gab es Post von Castle im Briefkasten . gg
