GOBLIN BLACK THUNDER. Preliminary info.
  • bronti
    • 16.10.2005
    • 3465
    • sven
    Quick first video explaining the GOBLIN BLACK THUNDER main concept...
    GOBLIN BLACK THUNDER. Preliminary info. - YouTube
  • bronti
    • 16.10.2005
    • 3465
    • sven
    AW: GOBLIN BLACK THUNDER. Preliminary info.
    Black Thunder setup!
    Thunderbolt 650/105
    Vbar NEO
    BK 7002/7006
    Scorpion 4525-520Kv
    HobbyWing 130
    Pulse 12s 5000 45c
    Running about 2300 head speed and can get about 3:30 of aggressive flying with the 5000 packs. 4000-4500mAh fly a bit lighter but don't fly quite as long.
    HobbyWing 130 working very well in this model! Comes down cold after a hard flight, the fan is there simply because I wanted to try it. I am quite confident it isn't required and I will likely remove it here soon. Internal governor performs quite well, BEC is strong and has been working great.
    Standard Vbar setup...14 degrees of collective, 8 degrees of cyclic, 120 agility, 90 style, 55 gain.
    This heli flies extremely well, light weight and fast. Lots of power and agility with a solid presence in the air. Optional 700 stretch kit will be available for it if you want.
    Setup for the nitro models coming soon. Waiting on them to be shipped back home from Italy.
    • tc1975
      • 18.08.2008
      • 6766
      • Timo
      • MFG Tangstedt
      ...und das alles mit nem 130er Hobbywing - Hammer!
      RAW 700 / Nitro - @VBar Touch
      • Fr3kayz
        • 10.06.2013
        • 672
        • Joël
        This is nice, that is nice and ohh this is nicee.
        Lol hättens mal lieber den Bert engagiert ;-)
        T-Rex 700L Dominator, Kosmik 200, Vstabi Neo
        T-Rex 700 Nitro Pro, OS 105HZ-R, Brain
        • olaf12
          • 06.10.2010
          • 2539
          • Olaf
          • Pampaflieger um Dresden/Regensburg
          Mich interessiert eigentlich nur das Landegestell von dem Heli.
          GruÃ? Olaf
          • Chase_360
            • 22.08.2014
            • 698
            • Ulrich
            • Gelsenkirchen
            Wieso nicht ?
            • Schraubcopterflieger
              • 15.01.2013
              • 2953
              • Dominique
              Dachte das wäre ein deutsches Forum?
              Was soll das hier? In englisch damit die Auftraggeber diese Werbeveranstaltung auch verstehen und nachprüfen können?
              • P300pilot
                • 13.11.2012
                • 147
                • Cees
                Wir sind doch Multi Kulti in Deutschland, deutsch / englisch / polnisch / arabisch - geht doch!
                • *wt98*
                  Optipower
                  Teampilot
                  • 13.02.2015
                  • 1614
                  • Italy
                  Was habt ihr vor zu verbauen in eurem zukünftigen black thunder?
                  make it better, fly with OptiPower
                  • Chase_360
                    • 22.08.2014
                    • 698
                    • Ulrich
                    • Gelsenkirchen
                    BLS 173
                    BK 7006
                    4525 Scorpion
                    130A Hobbywing
                    Neo
                    12S 4500mah
                    • bronti
                      • 16.10.2005
                      • 3465
                      • sven
                      Sebastiano Gabutti - SAB Goblin Black Thunder - YouTube
                      Flying the brand new SAB Goblin Black Thunder at the 4th Greek Heli Event. The heli is equipped with latest SAB Thunderbolt 650mm blades and 105mm tail blades, Kontronik PYRO750-56 and Kool Kosmik 200A, runs on Pulse 4500mAh 45C 12S, VBar NEO with VBar Control, BK 7002HV Swashplate servos and BK 7006HV Tail servo.
                      That setup at 2350rpm guarantee a flight time of around 3:10-3:30 minutes.
                      • tc1975
                        • 18.08.2008
                        • 6766
                        • Timo
                        • MFG Tangstedt
                        ...uns SO ausgestattet hat er sicher auch wieder über 5kg...
                        • *wt98*
                          Optipower
                          Teampilot
                          • 13.02.2015
                          • 1614
                          • Italy
                          Muss nicht unbedingt sein...
                          • bronti
                            • 16.10.2005
                            • 3465
                            • sven
                            SAB Black Thunder Highlights Flight by Kyle Stacy - YouTube
                            • charly39
                              • 21.09.2008
                              • 2066
                              • Karl
                              • UMFC Reichenthal OÃ?
                              _______________________
                              [FONT="Comic Sans MS"][FONT="Times New Roman"]SuziJanis700//Trex700FL//EXO500[/FONT][/FONT]
