ab 8min28 12s
SAB Goblin 570 Setups
Chris Reibert: 6s Setup
Flight Style: Big Air 3D
FBL System: iKON
Motor: Scorpion HKIII HK4025-1100KV
Pinion: 21T Pulley
Headspeeds: 1950/2200/2400
ESC: Castle Edge HV120 ESC
Governor: Castle Internal Gov
BEC: Castle BEC Pro
Cyclic Servos: MKS HBL950's
Tail Servo: MKS HBL980
Main Blades: SAB 570mm Blackline Blades
Tail Blades: SAB Tail Blades
LiPos: Pulse 5000/5500mAh 6s Lipos
Kyle Stacy: 12s Setup
Flight Style: Smack 3D
FBL System: Futaba CGY 750
Motor: Scorpion HKIII HK4025-550KV
Pinion: 23T Pulley
Headspeeds: 2200/2400/2800
ESC: Jive 120
Governor: Jive 120 at 47% / 83%
BEC: Western Robotics Hercules
Cyclic Servos: Futaba 272 HV's
Tail Servo: Futaba 276 HV
Main Blades: SAB 570mm Blades
LiPos: (2) Pulse Ultra 6s 3300 45c Lipos
