700N - MicroBeast - Stick Cam - IRCHA 2010
  • red_z06
    red_z06
    This was a 2nd flight after installation so the flight is not so good. Better video will follow soon.
  • red_z06
    red_z06
    AW: 700N - MicroBeast - Stick Cam - IRCHA 2010
    Setup:
    Heli - Align Trex 700N
    Engine/Muffler - OS 91HZ / Hatori SB20
    Radio Gear - Hitec Aurora 9 / Optima 9
    Servos - Hitec HS7940TH / HS7915HS (Prototype)
    Gyro / Stabilization - BeastX MicroBeast
    FBL Head - ADK Conversion
    Rotor Blade - SWE 700DCN FBL / 105mm tail
    Battery - ThunderPower 2s3800mah
    Regulator - Fromeco Kiwi
    Canopy - MaskPro
    Upgrade - Lynx Clutch, Lynx main bearing block
    Misc - SwitchGlo
    Zuletzt geändert von Uwe Caspart; 18.08.2010, 02:45. Grund: In true sponsership.... ;-)
    • red_z06
      red_z06
      Uwe Caspart
      I guess the web links are in violation of RC-Heli. Sorry about that.
